Question about Honeywell Heating & Cooling
Is the wiring for my old tstat (hunter 44155c capatible with your honeywell rth6500?
  • Honeywell Master
  • 1,875 Answers
Of course it is. Turn power off to furnace, take pictures of wiring, and install new. Possibly some settings may need adjusted but should be good to go. Good Luck!!
Posted on Apr 29, 2017
Cannot get Hunter stat 44155c that is connected to a Rheem 1210b to shut off after the stat reaches the set temp. How is an original 7 wire connected to the Hunter stat?
y is to condensor contactor wire
c is common
r is power
w/w1 heat strips
o/b reversing valve
e/w2/aux heat strip also
g is blower
For a rheem unit, make sure reversing vavle is set for "B" not O.
Blower may run for up to 120 seconds after shut off. My experience with hunter stats are not good (even out of box). Recommend honeywell tsat.
Apr 05, 2011 | Heating & Cooling
Wiring mdel 44155c unable to wire properly
what wire goes where on new thermostat my wire on old thermostat are red, white, green, and blue ro could u please tell where to connect them on this new thermstat.
Nov 02, 2010 | Hunter 30124 Air Conditioner
Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Sep 14, 2009 | Honeywell Programmable Thermostat Heater
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
