What can I do about my ear phone jack not working?
    Master:
  • Audio Player... Master
  • 923 Answers
Earphone jack ... for changing a tire? Earphone jack on WHAT?
Posted on Apr 29, 2017
Turn off the phone speaker when ear phones are connected?
that is a function of the ear phone jack some aftermarket buds do not plug far enough in to disconnect sound going to internal speaker tray another set
Jan 02, 2015 | Samsung Galaxy S 4G Cell Phone
Ear piece not working sony ericsson e16i
take the phone to the shop and tell him to check ear phone jack in the mobile
Sep 14, 2014 | Sony Ericsson Cell Phones
14 month old Ultimate Ears 700s and the jack has turned faulty. I can wiggle it around to get both phones to work, but, once I remove my hand from the jack, the right phone goes out. Is this fixable? ...
It is for sure that the wires have come out of the jack connection. This normally happens as the wires are always moved around as your plug and change.
The easy way out for you is to approach any electronics service center who can easily splice off the wires and put in a NEW jack which must be soldered.
This job can be done if you are able to handle a soldering iron and get to solder the jack with the connection on either terminals- just any tech will guide you to do this very easily.
Mar 08, 2011 | Ultimate Ears 700 Noise Isolating...
I have turned the tv on and in the top right hand corner there is a symbol for earphones and i cant get the normal sound back on
yoiu likely have a sound output selection in you setup menu .. or in some sets they sense the fact that ear phones are plugged in (switch in the ear phone jack) .. and that automatically shuts off the main speakers .. sometimes the ear phone jack gets damaged and the set thinks there is always an earphone plugged in .. if thats the case then the jack would have to be replaced or repaired ... or you could for the time being, run a cable from the ear phone jack to an external amplified speaker (like a computer speaker .. that would get your sound back at least until repairs can be made ..
Nov 27, 2009 | Cell Phones
One one ear bud works on my in ear headphones
YOU HAVE A BROKEN WIRE IN YOUR HEADSET, OR IN THE INTERNAL JACK CONNECTION. TRY A DIFFERENT HEADSET. IF THE SAME PROBLEM OCCURS THE PHONE JACK MUST BE REPAIRED.
Jan 11, 2009 | Nokia Consumer Headset
Ear phone jack needs to be replaced
If you know anyone with soldering capability the pads on the headphone jack just need to be re-soldered. Mine did the same thing so I re-flowed the solder joint and now it works perfect.
-Brad
Dec 08, 2008 | Dell Pocket DJ MP3 Player
Sandisk M250 ear phones Jack information 2.5 or 3.5 ?
It's the larger headphone minijack standard on most portable tape players etc., not the much larger one found on hime stereo equipment or the smaller one most often found on cellphones. So, "3.5" (mm?), I suppose.
Nov 10, 2008 | SanDisk Sansa m250 MP3 Player
Ear plug
That is normal for most mp3 players
If you are getting sound out of only one ear, then the headphone jack is broke - unfortunately, Philips does not have any more HDD models to send you as a replacement
Jul 15, 2008 | Philips GoGear HDD6330 MP3 Player
Volume is non-existant on LG VX 4400
When you press vol up & down it will indicate "ringer ear jack." This means the phone is stuck in ear jack mode expecting a wired head phone accessory. Remove the battery then unscrew and pull out the antenna and the black plastic sleeve. Then remove the for small torx screws and carefully remove the back. Take a tooth pick to the back of the ear jack an bend the retainer pin back. Put everything back in reverse order and it should work fine.
Nov 28, 2007 | LG VX4400
27 people viewed this question
 Grubhead
Grubhead
