Question about The Office Equipment & Supplies
What should you do with the barcode label that is located in step 2 on the CCF?
How do i create a barcode label
You can either see my simple Tool with 3-easy Steps to create a barcode label!
What kind of barcode symbology do you want to use?
Aug 09, 2013 | Zebra 105SL Thermal Label Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
I have had my laptop for nearly 2 years. In the last 3 weeks I have a white text appeared at the side of my computer stating that windows vista is not a genuine copy. I have tried to input the product key,...
Information about Genuine Windows is here:
http://windows.microsoft.com/en-US/windows/genuine
To find information about your Windows system, right click on 'My Computer' and you will see the product id and if it's activated.
If you can't find it, I suggest you phone Microsoft Support.
Aug 04, 2011 | Computers & Internet
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
Oct 29, 2010 | Zebra Stripe S600 Thermal Label Printer
Dear sir or mam ,i m having argox GE200 barcode printer which is not responding. when m giving print no response from the printer and any error also not showing.wat to do?
Hi.. Just follow these steps, hope this may trouble shoot your barcode printer.
1) Restart Your Computer/ Barcode Printing S/w / Barcode Printer/ and try now.
2) Even if it does not work, check the cable connectivity with printer and system
3) Even it is not working, try printer calibration or labels feed options in printers.
4) Check the proper sensor adjustments in printers,
Hopefully this should help you to get back your barcode printer online.
If you have any other queries with barcode printers, please email/contact us.
Regards Kirubakaran.Rv Web Marketing Manager Trridev Labelss Mfg Co Leading Labels Manufactures In Chennai Mobile - 96000 07995 www.trridevlabelss.com email kirubakaran.rv@gmail.com
Sep 03, 2010 | Argox OS-314 Label Printer
The printer is not feeding the label until the perferated line. it only feeds about an inch and then stops and then feeds another inch. on our other zebra once the feed button is pushed the printer feeds...
Simple yeah. Printer calibration is the problem.
see this video , http://vodpod.com/watch/3948392-how-to-calibrate-zebra-tlp-2844-printer
For over 4 years, Trridev Labels has provided Barcoding solutions and Barcoding equipment to a wide range of large and small companies in virtually every industry sector. Trridev Labels offers more than 10,000 brand name products and services such as Barcode Labels, Barcode Printers, Barcode Scanners, Thermal Transfer Ribbons (Wax, Wax Resin, Resin), ID Card Printers.
Contact Trridev Labelss Mfg Co – If you have requirement of Barcode Labels, Barcode Printers , Barcode Scanners, Self Adhesive Labels, Thermal Transfer Ribbons, Printer Heads, RFID Solutions, Barcoding Solutions. We provide you a complete solutions for barcode.
Call us at +91 – 96000 07995 / 98840 42305 To Get the Best Price Tagged with Best Quality.
Jul 02, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
48 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
