Question about Troy Garden
Oil coming from carb on Troy bilt 146
Runs like a top but oil pours out of carb
  • 39 Answers
Sounds like a blown headgasket
Posted on Apr 29, 2017
Troy bilt troubleshooting
might be low oil sensor trying to shut the engine down, on a hillside the oil would go to one side and the sensor is thing the unit is low on oil.
Jul 28, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
John deere lawn tractor rx 95
carburetor needs cleaning. sounds like the Needle valve is not doing its job
Apr 22, 2014 | Garden
Gas pouring into carb
carb float problem
Apr 22, 2014 | John Deere Garden
Why is my 8.5 hp troy built snow blower leaking oil while under strain
Make sure the crank case is not over full when not running and make sure the crank case breather is clear.
Dec 15, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troy built squall 210. Starts and runs for a few seconds. Decided to check the oil and gas poured out of the crank case. Im not talking a little. Im talking atleast a pint or two. Can some body explain...
You have a Troy Bilt motorcycle?
Crank case filled with gasolene indicates a carb problem ... typically, the float has a hole in it causing it to sink ... when this happens, the bloat valve can not turn off the flow of fuel and it runs into the combustion chamber, own past the rings into the crank case.
Many original Troy Bilt machines came with tank shut off valves, it is a good practice to turn this valve off when the equipment is not in use.
Thanks for your interest in FixYa.com
Mar 03, 2013 | Motorcycles
Gas runs through carbarator
if it is a 2 stroke engine replace the carb, if it is a 4 stroke try replacing the needle and seat. if the gas is running through the carb in a 4 stroke make sure you change the oil before trying to start it as you will have gas in the oil thinning out the oil and over filling the crankcase
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 12, 2013 | Troy-Bilt Garden
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
Not getting gas in the carb. changed pump. poured a littlr gas in the carb good compression but dies when gas runs out
get a oil can the thumb operated type and squirt some oil down the petrol pipe and make sure pipe is upwards so the oil runs into the pump then leave for a while to wet the valves in the pump then crank engine to make sure petrol comes up or just refit the pipe and pour some petrol down the carb and watch it go
Aug 16, 2011 | 1986 Dodge Ram 50
Getting fuell to carb new fuel pump and filters will start whn fuel is poured in carb
if computer command truck with an ECM replace the engine's oil pressure sensor. It has 3 wires to it and one runs to the fuel pump to prime upon starting the engine. Once oil pressure is acheived the computer switches that senors wires circuit off and turns on the fuel pump relay to take over the fuel pumps operations till you shut the engine off
Aug 07, 2011 | GMC K1500 Cars & Trucks
Garden Logo
75 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
