Question about Samsung Washing Machines
Morning Samsung front loader wf1752 water is spurting out of were detergent is placed under door and now seeping out underneath, have pulled apart pipes, are not split what could it be
    Top Expert:
  • 867 Answers
There are 2 solutions for this problem, the easiest solution is to turn the tap that supplies the water to the machine down so that it stops leaking, the second option is replacing the dispenser drawer housing, The housings warp slightly over time and allow water to leak out at higher pressures.
Posted on May 15, 2017
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for that awful mildew smell associated with front loader style washing machines.
Place the washer on the hottest setting you have with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
on Apr 05, 2010 | Washing Machines
Tip
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
Samsung vrt wf219anw front load washer leaks
Replace the front door boot/seal. Its not hard, some things just take longer than others
Apr 15, 2014 | Washing Machines
I have a Samsung Silver Care front loader washing machine. When I turn it on water comes out the detergent dispenser drawer and a little oozes out of the main front door. Any ideas? Thanks, Kelly
Remove the dispensing tray (look for an under side spring clip or release) and check the fluid exit point--the machine washes the detergent into the drum along with other washing compounds. You may be better off using a liquid detergent rather than a powder. This may also fix the main door leakage too. Hope this helps!
Aug 15, 2010 | Samsung WF328AA Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
There is water left in the detergent tray after the wash is over
This seems to be normal for ALL front loaders
I just leave mine open along with the front door to dry out
Nov 06, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
What makes a series III washer stink like stagnant water?
J. Garber:
ALL washing machines will build up deposits of gunk in places that you cannot see or readily access. In top loaders, the typical place is underneath the agitator and on the inside of the wash tub (part that holds water). This "gunk" typically consists of body oils, detergent deposits, calcium deposits, hair, dust, dirt, etc. This stuff gets and stays wet. Wet and warm plus "gunk" equals smells. Top loaders can easily solve this problem by removing and cleaning the center column and agitator, then super chlorinating a batch of wash water (no clothes). Fill the washer, putting in three or so cups of bleach, let sit for an hour or so. This should clean the tub. Leaving the top cover open will also help as well as washing smaller batches of clothes more frequently. I have also found that infrequent use of a washer will frequently cause the the residual wash water in the pump(s) to go stagnant. Running a quick small rinse before washing clothes will solve this problem. Front loading washing machines typically have a cleaning cycle and specific instructions as to how, as well as how often, to clean the machine. Have you read the operating manual? I find that leaving the door open and running a fan that blows air inside the machine for an hour or so after washing also helps dry out the machine and keeps mold and bacterial action down by drying out the machine quickly. Keep the door open if at all possible. Removing and drying the detergent dispensers as well as the detergent dispenser opening also helps. Changing detergent may also help. Most front loaders recommend HE detergent. Use the absolute minimum amount of detergent necessary to get your clothes clean which is often a couple of ounces or less. There are also products that claim to clean your machine and eliminate odors, but I have no experience with them. Keep it dry. Keep the door open. Use a fan to blow air around and dry the machine out. Run the cleaning cycle as often as neccesary.
Sep 04, 2009 | Kenmore Washing Machines
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
