Question about Home
Where can I buy a transmitter for a sharp- atomic weather station. I put new batteries in and can't set clock without the transmitter.
3 Suggested Answers
  • 30 Answers
SOURCE: skyscan atomic clock weather
Make sure the battery contcts are clean of any corrosion.
-AAT
Posted on Feb 22, 2011
jsterben
  • 3 Answers
SOURCE: How do I set the correct time zone on my Sharp
On the SPC595, there were no specific instructions to set time zone, either (default was Pacific, I'm in Eastern), so I'm hoping that what worked on this will work on your unit:
Try hitting the "UP arrow" when the clock is NOT in a setting mode. This is not referenced in any "setting time" area but rather the area of the instructions that tells you what each button does. My manual (if you can call it that) says the following:
"UP Button
In setting mode, press it to increase the setting value. Press it to switch the time zone P/M/C/E"
Posted on Oct 12, 2014
How do I reset the time. I put in new batteries but the time is way off
Why not refer to the instructions of the clock? And for most clocks, you can reset time from the buttons in the back of it.
Jun 12, 2015 | Sharp Atomic Weather Station Alarm Clock...
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
We have the sharp atomic weather station 1005. We have put 2 sets of batteries in the transmitter, but it is showing the battery needs changing. Can anyone tell me why
quite possibly the batteries you used were not the best for the task at hand .good quality ones like duracell will only last about 1 year
Feb 26, 2015 | ATOMIC Measuring Tools & Sensors
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
The outside temp is not displaying
If the clock uses a remote temperature transmitter, you may need to replace batteries.
Jan 12, 2013 | Sharp Atomic Weather Station Alarm Clock...
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Sharp SPC 373 transmittting temp 179 for a month
Unfortunately I have the same Sharp atomic clock with the same bad remote temp transmitter and having the same 179 result displayed. Can't find a replacement anywhere.
Sep 28, 2009 | Kitchen Appliances - Others
Home Logo
32 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
