Question about Garden
JD 425 STARTS WITH COKE ON AND RUNS TILL COKE SHUT OFF.???????
2 Suggested Answers
wadembly
  • 513 Answers
SOURCE: My LX 425 starts and runs great but it back fires
change the spark plugs to a cooler plug it is burning to hot
Posted on Jul 08, 2009
Jd x 310 tractor, I replaces plugs, fuel filter air filter, still run rough an misses, runs fine sitting still, if u engage blades starts missing,or if u muve tractor it starts missing. HELP
Try adding a full bottle of Techron fuel treatment to gas tank. Full tank with gas then run engine till tank is empty. Refill with gas problem should be resolved if caused by varnish in gas.
Nov 25, 2017 | Garden
JD JS45 walk behind mover. Starts, runs fine for 5 minutes, then stalls, won't restart till i pull the spark plug and cool the motor, plug down. then same thing starts, runs for 5, stalls.
Probably either a fuel or a spark problem. You need to check for the presence of a good spark immediately the engine stops - by using a spark gap, a spare spark plug or a propriety spark indicator.
If the spark is found to be absent the fault is likely the ignition module but check all connections and the stop switch operation before replacing.
If the spark is present then the fault is probably fuel-related and is the sort of thing a tiny droplet of water in the carb could cause...
Jul 23, 2016 | Cars & Trucks
335 JD garden tractor will not start part of the time
till it cools off ??? suspect an ignition issue but what engine does that have ???
Oct 19, 2014 | Garden
Runs great till you shut it off
Does it turn over very slowly, if so it would be your starter motor, have that checked first
Jan 04, 2014 | Chrysler LHS Cars & Trucks
JD 425 only runs on right cylinder.....no spark on left plug.....replaced coil and connector.....?
I was in a strange temper last 7 days, though, and I decided that I needed to approach him. After the show, as soon as the music stopped, I would merely introduce myself and tell him that I was a big fan, just to clear the air. Computer Mouse Slow Mouse Reaction AmanStino
Apr 10, 2012 | Cars & Trucks
Model 425 jd getting fire at plugs changed fuel filter primed carb will not start
when you turn the key on to the run positon do you hear a clicking sound coming from the carburator? this tractor is equipped with a fuel shut off solenoid on the carburator if you dont hear the clicking sound solenoid is either not getting 12vdc or it is defective.
Aug 29, 2009 | John Deere Garden
JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
