Question about Toro Garden
Toro 3250 units lower lift electrical fault - Toro Garden
Error code 40
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 40
Mar 11, 2014 | Precor Exercise & Fitness
Error 40 on precor c964i
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Feb 22, 2014 | Precor EFX 546i Elliptical Version 4
Getting an err40 code
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Aug 27, 2013 | Precor EFX 5.21s Elliptical Cross-Trainer
How to engage grass catcher on toro 22
Lift rear door, catcher bag has a hook on each side that must be hooked over bar on each end.
Jun 17, 2012 | Toro Garden
Precor 9.31 stopped and error message 40 is displayed
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jun 07, 2012 | Precor 9.31 Treadmill
PRECOR EFX 546 ERROR CODE 40
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Oct 17, 2011 | Precor EFX 546i Elliptical Version 4
Flat right reat tire. Cant get a jack under to lift tire off ground to take it off. Can't lift front enough to get block under that might raise rear after lowering front. How's it supposed to come...
Hello there, the Toro 52" 27hp z master has an Exclusive Toro Z Stand on 27 hp (20.1 kw) models provides an on-board tool to simply elevate the front end of the machine and provide access to the underside of the deck.this Z stand gives access to the underside of the unit to enable you insert a jack under to change the rear tire.rockmeister_15.jpg
Here is a link to help you download the service manual, operator manual, parts catalog and setup instructions. These give more insight as regards getting the tire changed.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 10, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A...
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
I need to dissasemble a toro 550 leaf blower
The gas units have TORX screws holding the covers on exclusively. Phillips or slothead screwdrivers won't undo the fasteners. I am not sure whether this is a gas or electric unit and am unsure of the fasteners used on an electric Toro (if it is).
Jul 05, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
