The reset button is stuck and it won't turn on now. Is it safe to unscrew it off wall
    Top Expert:
  • Televison & ... Master
  • 15,148 Answers
What are you requesting will need more information either edit or resent request
Posted on Apr 29, 2017
TV is stuck on channel and has a black screen. None of the buttons on side of TV work, can't even power it off, have to unplug it from the wall.
In fact, you have done a hard reset to this set, by disconnecting it from the main power supply line overnight. It will be best to contact any service technician in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 03, 2014 | Seiki Televison & Video
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Htc one sv stuck in safe mode volume buttons inoperable
Turn off the device. Remove the battery, hold the power button down for 5 to 10 seconds. Reinstall the battery, this should reset the device back to normal. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Jul 16, 2014 | HTC One SV
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
My computer won't go past the black screen when it's trying to boot up
Did you try and reset the memory? Turn the laptop upside down and unscrew the compartment for the memory. Also, try removing the harddrive and resetting it.
Jan 29, 2013 | Dell Computers & Internet
Only turns on with remote and won't stay on
Power button on the television itself may be stuck - go to the unit and press the power button se if it engages. If it depresses and sticks there is your issue - if it does not check the remote take out the batteries and unscrew the unit take the rubber pad out of the casing and spray out with canned air. If that doesn't do it - try unplug the tv from the wall for 1 minute or 2 and replug-in and see if the problem persist if so you will need to contact a tv repair shop but it sounds like the button on the tv needs to be cleaned because something is holding the power position in a spot to turn the unit off
Jan 14, 2013 | Mitsubishi WS-65411 65" Rear Projection...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
I have safe mode on my phone and i cant turn it off cant use apps i want how do i turn it off? i have a mytouch 4g i factory reseted and rebooted it doesnt work help
Please check your menu key and see if it is stuck. For your phone to boot into safe mode, the menu key needs to be held at power on, so if after turning it off and doing a factory reset you are still in safe mode, then your menu key stuck. I have heard of the g1 having issues with the menu key getting stuck and a replacement is needed. How old is your phone? Are you still under warranty with tmobile? Let me know if you have any other questions.
Mar 01, 2011 | Cell Phones
Panasonic DVD player stuck in safe mode
Just got off with the Panasonic people. You have to turn it on, then hold down the VCR play button and channel up button at the same time until the unit turns off. This will reset the whole player. Then turn it back on & it should open!
Nov 29, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
