Question about Amana Washing Machines
I have amana top loading washing machine. Single button forstart/pause/unlock lid. I put clothes in. It locked lid. Will not go to any other function. Will not unlock even after solid li
    An expert who has answered 500 questions.
  • 512 Answers
Make sure water is on, You should be able to cancel a cycle by holding the start button for 3 sec.
Posted on May 01, 2017
  • 5911 Answers
SOURCE: ''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Posted on Nov 14, 2008
  • 26 Answers
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
  • 1531 Answers
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Posted on Jan 23, 2010
SOURCE: lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
Posted on Jan 26, 2012
  • 9472 Answers
SOURCE: whirpool cabrio wtw5500xw top load washer will not start lid light flashes then goes out and into flashing pause mode
You will need to replace the lid latch assembly. Here is the part to order.
Here is a video to show you how to replace the lid latch.
Posted on Nov 19, 2012
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
Sep 6, 2013 - Uploaded by
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
How can I bypass the lid lock model # NTW47018QO
the lock function was added to elimimiate the danger of someone sticking there body parts inside machine (they can kill a human or pet) while its operating this is a safety function and really should not be bypassed unless in very special uses , this function used to be done by a lid switch that shut power off to machine , the lid lock now is easy to disengage just press the stop button in as soon as machine stops moving the the lid should unlock allowing you to open it to Add/remove items , I do warn folks that if any items are added after fill step the auto water level sensor has already made its calculation of needed water so what's in there after more clothes are added will not have sufficient water level to clean properly resulting in disappointed washing results
Sep 23, 2015 | Amana Washing Machines
Place unit in diagnostic turn knob till rinse and spin are lit press the start button lights should go out press start again the lid should lock light on press again unlock and off
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. top load...
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Unlocking sharp
These machines are set that way. Once started, even if you stop it you have to wait for a timer to unlock it which takes about 3 minutes.
Jun 30, 2013 | Washing Machines
Whirpool cabrio wtw5500xw top load washer will not start lid light flashes then goes out and into flashing pause mode
Nov 18, 2012 | Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
My maytag neptune fav6800vaw washer will not complete the wash cycle. i press pause but the lid does not unlock so the machine is still filled with clothes & water.
I would go into Service Mode and try to unlock the lid latches. Google this
Neptune TL Washer FAV6800AWW
Go to the 5th post down there is a link to the Service Manual. The Service Manual will show you how to get into Service Manual and unlock the lid Locks. If you can't unlock in Service Mode the Service Manual will show you how to release the washer top from thew base to remove your clothes.
If you need additional help post in that forum for help ; Maytag/Magic Chef/Admiral/Jenn-Air
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
