Question about Sanyo Office Equipment & Supplies
Our Sanyo PLC-XT16 projector is projecting a pixalized screen. We just replaced the computer an the tech experienced this and found a correction online but I don't know what it was.
  • 3 Answers
SOURCE: Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Posted on Feb 08, 2008
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Posted on Jun 03, 2009
  • 43 Answers
SOURCE: Connecting my pc to a sanyo plc sw30 projector
True, The 15 pin connector at the back of your computer (the one your screen normally plucs into {its blue color coded}) Is your vga output, Now on the projector side, you have the same connector, Called your VGA input. You just need to connect a male-male vga cable between your projector, and pc, and puth the AUTOSEARCH button on the projector. And you should get an image.
Here is the repair schematic.. They cover EVERYTHING. from repairing, to usage.
Posted on Dec 03, 2009
The projector is shuting down due to overheating after every 30min. how can i correct this?
There are four air filters that are accessible from the bottom of the projector .... make sure they are all clean.
Jul 18, 2011 | Sanyo PLC-XT16 Multimedia Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
No bright just for one second
when you connect a source, it refreshes your external display nothing major or minor, its normal
Jan 24, 2010 | Sanyo PLC-XT16 Multimedia Projector
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XT16
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
Apr 15, 2008 | Sanyo PLC-XT16 Multimedia Projector
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
42 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
