Question about Toro Garden
Toro 3250 d units lower lift electrical problem
How do you push a toro riding mower
riding mowers have a bypass system to be able to move a machine that's not running. At the rear of unit you will find a heavy wire coming out the back end lift a little and pull this out. you should now be able to push unit
Oct 18, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to engage grass catcher on toro 22
Lift rear door, catcher bag has a hook on each side that must be hooked over bar on each end.
Jun 17, 2012 | Toro Garden
Flat right reat tire. Cant get a jack under to lift tire off ground to take it off. Can't lift front enough to get block under that might raise rear after lowering front. How's it supposed to come...
Hello there, the Toro 52" 27hp z master has an Exclusive Toro Z Stand on 27 hp (20.1 kw) models provides an on-board tool to simply elevate the front end of the machine and provide access to the underside of the deck.this Z stand gives access to the underside of the unit to enable you insert a jack under to change the rear tire.rockmeister_15.jpg
Here is a link to help you download the service manual, operator manual, parts catalog and setup instructions. These give more insight as regards getting the tire changed.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 10, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A...
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
What is 3250 wattage i am looking at a gaggia machine to buy and it says it is 3250 wattage will i need special electrity power thanks
Hello and Welcome to FixYa!
Please explain your query a bit more... What I understand is that you need to know what that 3250 W means. Actually this the power (approximately maximum) that can be generated using that equipment... Every electrical equipment consumes certain power e,g. Ceiling fan ~100W, Iron ~1000 e.t.c. You wouldn't need any special electricity power as such.....
Regards....
May 24, 2010 | Briggs & Stratton 3,250 Watt 6.5 Hp...
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
SERIOUS WITH TORO 15
Toro has a 2 year over the counter exchange on electric trimmers. If the retailer will not comply, Call the ph. # on the back of your manual. Toro should send you one free of charge
If you have any questions, call me. 920-759-6246 Dave
Aug 07, 2009 | Toro Electric Trimmer
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
