Why does the machine shave the ice, but won't mix the drink? The liquid stays in the bottom. Also, motor smells like its burning when the machine is on. Just got it out of the box!
    Top Expert:
  • Washing Mach... Master
  • 12,744 Answers
If not working correctly then return for replacement or repair
Posted on Apr 29, 2017
I started vacuuming and the vacuum motor slowed down, then stopped. I smelled a burning smell. Then I discovered the next day that the bag bottom was wet and falling apart. Sebo X4 model
sucked up liquid goes with the air through the motor
that would cause the motor to burn out
with the current low cost of new vacuums , the repair /replacement of the motor would be close to a new unit
take it to an appliance repair shop and get a proper diagnosis and quote
Dec 02, 2016 | Vacuums
How do I lubricate the ice shaver rod-it squeaks and with what kind of lubricant?
If you can visually see the rod, use a few drops of cooking oil. If it leaks into any drink, you wont get sick. Don't use mineral oils.
Feb 29, 2016 | Nostalgia Electrics MOS-400 Counter Top...
What kind of fresh drink can i make with an ice shaver?
In the place where i grew up there was an ice cart pulled by two guys who shaved ice on the spot and made very yummy "granita"s (kind of like a slush).
They shaved enough ice to fill a cup and added a bit more so that it looked round and solid at the top. Then they poured on it a bit of flavored syrups. They used to have plenty of fruity flavors that you could mix. The ice would be sweetened and flavored by the syrup and on top they would sprinkle little pieces of fruit or coconut shards. It could be eaten with a spoon and sucked with a straw and it was the most appreciated dessert of the summer.
You could buy a couple of small bottles of syrup to have some flavors that you can mix up into different combinations and make customized "granita"s for your guests.
And even if there is leftover syrup you can keep it for next time as it lasts forever!
Jan 05, 2014 | Kitchen Appliances - Others
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
My margaritaville shaves too much ice into the blender, so it doesn't mix.
When mine did that I just put in less ice the next time and I experimented to see how much liquid to add. Once I did the 2nd and 3rd batches of drinks I got the hang of it.
Sep 18, 2010 | Margaritaville Frozen Concoction (DM1000)...
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    K45 started smoking while mixing cookie dough
    There is the possibility that if the mixer is 30 years old and it has never been serviced that the gasket around the gear case is leaking oil and in that case it would not be hard to get liquids on the armature or the stator as the gear grease in the transmission is vegetable base grease and it separates into liquids and solid and when the head is tilted up the failed gasket allows the separated oil to leak down and to the rear onto the mixer right onto the motor parts. It maybe nothing more that cleaning out all the old grease and re-packing and adding a new gasket.
    Dec 14, 2007 | Food Mixers
    Washing Machines Logo
    32 people viewed this question
    Top Washing Machines Experts
