Question about Garden
I have a 450 rancher and it runs great except when u hit the gas it boggs down and shuts off what causes that
  • 40 Answers
SOURCE: 1988 454 efi timing and fuel prob??
could be that your distributor is out a tooth
Posted on Apr 15, 2009
  • 109 Answers
SOURCE: weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Posted on Apr 16, 2009
  • 3567 Answers
SOURCE: 04 exc 450 wont rev
Pull the slide and move the jet needle clip down 1 or 2 notches.
Posted on Apr 21, 2009
  • 7 Answers
SOURCE: yamaha warrior atv [yfm 350] bogging problem
Try checking the switch for your parking brake. It is the top wire in the clutch handle boot. This wire connects to your CDI box, and restricts the RPM's while the parking brake is engauged. To find out for sure, trace the wire down to the plug under the headlight assembly and disconnect it. Now try starting you machine and give it some throttle!
Posted on Jul 08, 2009
  • 11 Answers
SOURCE: engine starts, idles fine, but boggs when gas applied
mess with the high and low motor screws
Posted on Sep 09, 2009
Hello i have a rancher 455e with no spark at times runs a short time boggs down and dies then no start or spark ????
No spark could be a number of issues. Break in ignition wire, faulty switch, incorrect timing space, faulty ignition module, bad sparkplug or the spark plug lead.
The running problem is most likely a fueling issue, check the fuel lines, filter and make sure fuel is getting into the cylinder.
Feb 20, 2016 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky boggs down
Make sure your fuel is good, fresh and properly mixed. Airfilter clean and correct resistor plug.
Apr 28, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Motor skipps during acceleration on 1998 s10 pick up 4.3 v6
a bad plug wire will break down when accelerating but act ok when idling change plugs and wires
Dec 27, 2012 | 1998 Chevrolet S-10 Pickup
Rancher 455 wont stay running
you need too adjust the high jet ccw (making it richer) do do that takes
a little work cause you need a special tool but I can help you around that if you like. let me know
Jul 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Looking for proper h/l jet settings on my husqvarna 266 se chainsaw..or a manual i can download ...i found one...but it was in swedish
rule of thumb is 1 torn out from closed will get you started. then run at high speed and richen the H screw till you hear it just starting to bogg down every few seconds. Then let off the throttle and adjust the L screw till it runs smooth the richen it a quarter turn. Thats the old fashioned way I have been using for 40 years
Nov 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
04 exc 450 wont rev
Apr 21, 2009 | 2004 KTM EXC 450 Racing
Idle problems after throttle is closed fast.
sounds like an overly rich condition when you let throttle snap shut no air enters or at least minamal air enters the engine and with to much gas the engine will bog down until the extra gas burns off(5 seconds) check floats height and make sure jets are secure and make sure the choke is all the way off
Dec 13, 2008 | Harley Davidson Harley-Davidson Motorcycle...
When truck first warms up it bogg when i hit gas
dude seriously the oil is cold and cant circulate, all cars must warm up when their cold. if you dont let it warm up you could be damaging critical parts to your engine
Aug 25, 2008 | 1989 Jeep Cherokee
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
