Question about Intex Pool & Spa
How can I fix E95 code on intex spa? I have cleaned all filters and everything. When I turn on the heat that's when it gives the code and it's not hot at all. Please help
    Top Expert:
  • Intex Master
  • 8,502 Answers
If recirculation pump running bad heater element
Posted on Nov 12, 2017
Healeyman
  • 1198 Answers
SOURCE: we have a spa quip 2.5 maxi flow spa pump,tried to
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Posted on Apr 17, 2009
  • 40 Answers
SOURCE: Tumble dryer will not get hot. Says Filter needs
Sometimes when the dryer exhaust vent is clogged, it causes the dreyer not to work properly. If you have cleaned both the filter and exhaust tube it may be the heating element itself that is causing the problem.
Posted on Dec 07, 2009
Testimonial: "Many thanks for that, I appreciate your help."
Coastsider
  • 331 Answers
SOURCE: error 6 thermal cut out keeps turning the spa off
Check for proper water flow and disassemble any bypass governor and inspect for blockage
Posted on Apr 14, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
  • 3 Answers
SOURCE: low flow indicator on saltwater pool filter
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
Posted on Jul 08, 2010
Our Intex spa pump will not turn on
does the unit power up if not check and test the ground fault safety plug they can fail --if powers up and pump not working then the your problem is most likely the ceramic rod that holds the motor /impeller in place they have a big problem of breaking and intex doesnt sell a separate pump or the replacement rod the following link can show some quick fix but if you buy a brazing / welding rod the same thickness -home depot sell them 9.99 a box you only need 3" and need to clean flux off
Intex spa E95 cheap fix
Jun 04, 2017 | Intex Pool & Spa
How do you fix error code E90 in my intex pure spa pump? The control panel chirps and will not heat the water.
This fault code is No water flow sensed.
possible bad pump?
• Ensure the unit is plugged and switch on.• Ensure the outlet cover grid is clean and free
from obstructions.• Clean or replace the cartridge, see
Maintenance and Storage section.
• Ensure the in/outlet connections on the spa tub and filter pump are not blocked.
• If problem persists, contact Intex Service Center.
Corporate Tel # 1-800-234-6839
http://slink.intexdevelopment.com/b2cmnl/B2CMNLServlet?instantiate=B2cMnldownloadApp&action=pub_mnl&filnam=250IO_A0_1411_EN.pdf
http://www.intexcorp.com/support
Mar 21, 2015 | Intex Pool & Spa
WHy is My intex pure spa is not heating anymore
Bad heater or possibly an easy fix, by cleaning or replacing your filter?
Owners manual attached:
http://www.pool-j.com/pdf/574616.pdf
Mar 09, 2015 | Intex Pool & Spa
What does SPH MEAN?
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
The SPH Error and how to Fix
Aug 24, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
Pool & Spa Logo
952 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
