Question about Raleigh Cycling
What is sence cF 1505 raleigh bicycle frame number ?
  • Raleigh Master
  • 1,189 Answers
If by your almost unintelligible question you are asking what CF 1505 means on a Raleigh frame, I would suggest you Google "Raleigh bike serial number" and see what you come up with. If you don't have the courtesy to provide a clearer question and more information I don't see why anyone should make more effort than you.
Posted on Apr 30, 2017
I have a Raeigh ladies bike with frame number 556712P. It was sold to me as a 1948 model, can you confirm this please.
All you have to do is Google Raliegh serial numbers and choose the first link. It appears it was manufactured in either 1947 or 1948. Raleigh Serial Numbers Charts
Sep 25, 2016 | Raleigh Cycling
Raising handle bars
Should be a set screw or release on the frame where the handlebar stem inserts into the frame. Lossen the connection and with a friend if necessary push down on the frame and pull up on the handelbars to rise the stem. You might need to spray some lubricant where the stem fits into the frame.
Apr 15, 2014 | Raleigh M80
Location of serial number
Most if not all bikes are stamped on the bottom of seat tube. Historically that has been the case for Raleign...and Raleigh-Huffy.
Dec 11, 2013 | Raleigh USA Bicycle Company Retroglide
Does anyone know how to lower the seat on a Raleigh SC30 Bicycle?
usually, the saddle is mounted onto a male shaft that fits into the rear female of the frame - this can be loosened by undoing a nut located under the saddle. it will loosen and you can then twist it up or down - it still remains quite tight. don't forget to re-tighten.if this is the obvious solution that you have attempted, then I apologise, but this is how all saddles are adjusted - I thought - here in UK at least
Mar 25, 2012 | Raleigh USA Bicycle Company SC30
I have some space between the rear axle and the bearing hub on my Raleigh M40. Can you tell me if you have both an axle and the the bearings hubs for each side?
We don't supply parts. Advice. Take the wheel to a bicycle shop for an assessment as the parts are not universal among the different hub makers.
Aug 20, 2011 | Stickers Raleigh Mountain Road Tri Race...
Adjusting brakes on relaigh bmx
Vist the Raleigh (note the spelling) website amd download the Single Speed Manual. Page 13.
You could also use any Search Engine and enter "adjusting brakes on bmx bike" for video instructions.
Jul 07, 2011 | Mountain 3 Raleigh Bikes Bmx Road Frame...
Hello, I just bought a raleigh devon 27 with alu frame. I want to raise the "steering tub" since the handlebar is to low compare to the saddle. How is this done ? Thanks, Kjell
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between aerodynamics and uprightness when needed.
Apr 01, 2011 | Raleigh Diamondback Men's Edgewood LX...
Rear axle broken on Raleigh road bike, can i/ how do i replace it
Is it the axle in the hub or a skewer (quick release) that is broken? If it is the skewer, those can be replaced. If it is the hub (with a through-axle), then you would do best to buy a new wheel.
Sep 06, 2009 | Stickers Raleigh Mountain Road Tri Race...
Does anyone know if all of the components from a 2000 year model Raleigh Serengeti Mountain bike will fit on a 2006 Trek 4500 frame? I am looking at upgrading to a lighter frame, but like the components on...
They ought to. Bicycle components are quite universal. You may run into a part or two which won't fit (front derailleurs have to fit frame design [especially on full-suspension bikes] as well as tube diameter), and you must bear in mind that the geometry of the new frame will most assuredly be different, so your handlebars and stem may no longer be familiar or comfortable to you. Good luck!
Aug 26, 2009 | Cycling
Cycling Logo
49 people viewed this question
Top Raleigh Cycling Experts
85 Fiero SE
Level 1 Expert
Are you a Raleigh Cycling Expert? Answer questions, earn points and help others
