Question about Rinnai Heating & Cooling
Rinnai RL94i error 79 - Rinnai Heating & Cooling
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Where is the leak sensor located?
Rinnai V65iN Installation Instructions and Product Brochures . Please school to the bottom of this link. You find a directory which includes technical manuals and support. Provide the information. And someone will get right to you. You probably fixed it by now. Here is your sourcing.
Apr 28, 2014 | Rinnai V65i-N Internal Natural Gas...
How to fix Rinnai code 79
Let it dry out.
If it wont fire because of the error, try powering it off and back on. Also being new, it would be under warranty
Jul 20, 2013 | Rinnai Water Heaters
How do you fix rinnai tankless water heater code 79
Do not spend 500 on plumber to determine that condensate drain was not installed properly on vent line, and that acidic water from combustion by-product has been dripping down into tankless and burning hole through the special-alloy heat exchanger instead of going down into floor drain and corroding your plumbing pipes.
Do not spend hours fulfilling the required monthly and yearly maintenance, or spend money on service call each year to get the burner cleaned and gas pressure checked on your tankless computer that heats water...
Instead, fix any tankless problem, any brand tankless, same day do-it-yourself for $385, by replacing 1 part: the whole thing:http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
Gene
What does code 79 mean for the rinnai RU98i? It is beeiping and flashing 79
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Jan 09, 2013 | Rinnai Water Heaters
Designjet z2100,what is System Error 79:04
I researched and found several options to fix, hope it works for you.
There are two (2) ways to fix 79 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 79) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Click here follow the steps to fix error 79 and related errors.
To Fix (error 79) you need to follow the steps below:
Step 1:
Download (Error 79) Repair Tool
Step 2:
Click the "Scan" button
Step 3:
Click 'Fix All' and you're done!
Compatibility: Windows 7, Vista, XP
Download Size: 1.5MB
Requirements: 300 MHz Processor, 256 MB Ram, 22 MB HDD
79 Error Code is caused in one way or another by misconfigured system files in your windows operating system.
So, If you got 79 Error then We strongly recommend that you Download (Error 79) Repair Tool.
This article contains information that shows you how to fix your windows 79 error both (manually) and (automatically) , In addition, this article will help you troubleshoot some common error messages related to 79 error code that you may receive.
Nov 14, 2012 | HP Office Equipment & Supplies
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 403 FT
who did you talk to at rennnai?
let me know i deal with them on a buisness leval.
Mar 27, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004fa
page 35 of the following: http://www.rinnai.us/Rinnai.aspx/FileLibrary.aspx/DealerResources.aspx/DocumentsLibrary.aspx/WallFurnacesDirectVentMainHeatSource.aspx/RHFE1004FA.aspx/GeneralInformation.aspx/456RHFE1004FAManual32003.pdf.aspx hope this helps :)
Dec 24, 2006 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
87 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
