Question about John Deere Garden
How to remove the old lower hood on a john deere lx178
  • John Deere Master
  • 7,515 Answers
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX172 LX173 LX176 LX178 LX186 LX188 LAWN GARDEN TRACTOR Service...
Posted on May 17, 2017
5 Suggested Answers
  • 885 Answers
SOURCE: Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Posted on Jun 17, 2011
  • 6468 Answers
SOURCE: john deere lx178 will run in reverse when i try to go forward bogs down to a crawl
i have found over time the linkage wears and the rod needs to be adjusted to make up for the wear
Posted on Jun 14, 2012
Terry Corrow
  • 10875 Answers
SOURCE: The deck mower on my John Deere LX178 is all the way down and will not raise. Any suggestions?
push down on the button to raise it
Posted on Jun 03, 2015
Terry Corrow
  • 10875 Answers
SOURCE: I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
John deere lx178 lower hood installetion instruction
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Apr 29, 2017 | John Deere Garden
Why does 345 john deere run hour then stop?
Mine doing the same. Must have something in the tank. Took gas line apart for it enter filter and blew in to it. Works fine now.
Sep 04, 2014 | John Deere Tractor Starter 285 345 2243...
How to repair pto on 2210 ?
Buy one, take old one off, put new one on. Be careful not to damage plugs or wires while reconnecting. If you cant do this by using common sense then you probably should have a shop do it for you. Its not very hard honestly. Good luck.
Nov 07, 2013 | John Deere Tractor Starter 285 345 2243...
Do you have a wiring diagram for the starter on a John Deere 285 garden tractor? The old starter was removed and no wires were labeled.
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
Jul 30, 2011 | John Deere Tractor Starter 285 345 2243...
Jun 16, 2011 | John Deere Garden
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Garden Logo
223 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
