Question about Microwave Ovens
Please kindly help me on the most effective way to clear the error E141 code from my gaggenau BM270/271 MICROWAVE. I have earlier tried the clock test prog reset as suggested but it didn't work
SOURCE: Shuts off, must reset clock
I had this problem also, but what happened with mine is that it popped about 1/2 the bag and then the light popped inside the microwave and it shut down completely. My husband went out to see if the circuit breaker popped, it didn't, but he switched it anyway and the microwave came back on. So he put the micro on a power surge protector, and we tried again, but this time we used the minute timer and it just popped about 1/2 the bag and then blew. The surge protector still was working and so was the outlet, but the microwave was blown. About a 1/2 hour later, I looked in to see the micro and the clock had come back on. We just purchased this at Home Depot this past weekend, should we take it back and get another one? or is it our electical outlet?
Posted on Mar 12, 2007
  • 3130 Answers
SOURCE: microwave stops working
sorry to say the control panel sounds like it is defective.There is a microwave guy here that repairs these panels, look him up and contact him for the panel repair information. Good Luck
Posted on Apr 29, 2007
  • 3 Answers
SOURCE: Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Posted on Feb 14, 2009
  • 267 Answers
SOURCE: Microwave beeping and F2 error code
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Posted on Sep 23, 2009
  • 185 Answers
SOURCE: Heard microwave beeping. Went in
probably a defective keypad. very common samsung failure.
Posted on Aug 04, 2011
I have the SE code on my Samsung microwave. I have replaced the touch pad but the code remains. Any further advice? What is the purpose of the second tail on the pad; not the one that goes into the plug...
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement, if it has already been replaced then it is better to replace the ribbon cable connecting the board. Please get back to me if you have any other questions.
Aug 26, 2011 | Samsung MW1080STA Microwave Oven
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
Model number 721 82364200. Code F9 continues to show up. Seems to be connected to clock. Works intermitting. Makes a noise when working but is very inconsistent. Not sure what to do.
Sorry to read about your problem, I hope this helps you out.
The F9 error code indicates an inverter failure. If you continue to receive the F9 error code after unplugging the unit for 5 minutes, the control system assembly may need to be replaced.
Note : Microwaves are not good do-it-yourself projects. Microwaves are inherently dangerous to service. Internal capacitors can retain a lethal electrical charge even when the microwave is unplugged. A microwave radiation leakage test must be performed on the unit following any repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kenmore Microwave Ovens
Panasonic microwave nn-sn668b.. after cleaning it earlier today i went to use it and it didnt work. the time reads 00:00 as if a loss of power had occured (but didn't). The only button that seems to...
If the clock is not set, nothing will work as the controls require the time to be working. Press Clear/stop twice and press clock, set time and press clock again.
Hope this helps.
Dec 23, 2010 | Microwave Ovens
How to set the clock please?
One of these sequences may work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 25, 2010 | Smeg S43KIT3750EB Microwave Oven
Setting clock
It depends on the brand and model.
Normally it's a sequence like:
If not, please post a new inquiry with your correct brand and model.
May 23, 2010 | Magic Chef MCD1311ST Microwave Oven
How to set the clock on my sharp carousel microwave
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Sep 25, 2009 | Sharp Microwave Ovens
I want to see the clock on my microwave amana rcs820bl
Set the clock?
Normally one of these combinations will work:
Please write back if you need further help.
Sep 07, 2008 | Amana Microwave Ovens
Error code F3H on model GH5184XP
F3H is a humidity sensor error.
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Whirlpool Microwave Ovens
I have SE code on Samsung SMH7177STE Microwave any advise how I can fix that ?? thank you
The -SE-error is a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
William E. Miller, AS-EET
Jan 23, 2008 | Samsung MW1080STA Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
