Question about GE Microwave Ovens
How to set clock on GE microwave - GE Microwave Ovens
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Posted on Jan 10, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Posted on Jun 24, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave ge spacesaver touchpad does not work except for the
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
You can download GE owner's manuals and installation instructions here.
Posted on May 30, 2010
Why isn't the display responding?
The interdace that converts pushes into signals may have died, you may need a new front panel...they may be available...had to change 2 on our old toshiba
Jul 15, 2015 | GE Microwave Ovens
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
Nov 02, 2014 | GE SpaceMaker Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have GE JVM1540BMC. None of the buttons work so I cannot microwave and the exhaust fan does not work. It says "Please Press Clock". How can it be fixed?
You need to set the clock before it will let you do anything more...push the "clock" button and follow the on screen instructions to get it set so you get use the microwave.
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Aug 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
HOW DO I RESET MY GE JE1549GW MICROWAVE
Terry I am assumming that you are referring to resetting the clock. If so, push the clock button then set the time then push the clock button a second time and you should be all set.
Feb 08, 2009 | GE JE1540 Microwave Oven
How do I set the clock on a GE Spacemaker microwave oven?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
