Question about HP Office Equipment & Supplies
Hp photosmart 2575. How to connect too my tablet
ctf1800
  • 4402 Answers
SOURCE: HP Photosmart 2575
try this site
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01859&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Posted on Jan 02, 2008
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
  • 521 Answers
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Posted on Aug 14, 2008
  • 111 Answers
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Posted on Apr 13, 2010
I have an imac 9.2 can i use the photosmart 2575
Yes, HP Photosmart 2575 printer requires Mac OS v9.1 or higher
Feb 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
How to get free download for a hp 2575 photosmart manual frank
Hello there
Here is some information below that will help you get the manual ok?
I hope that this is very helpful
best regards michael
HP Photosmart 2575 Manuals, Support and Troubleshooting ... Free download of HP Photosmart 2575 User Manual. Troubleshooting help from
experts and users. Ask our large community for support. http://www.retrevo.com/support/HP-2575-Multifunction-Printer... - 107k - Similar pages HP Photosmart 2575 review - Multifunction Printers Quick links to useful Expert Reviews for HP Photosmart 2575 describing pros and
cons. User sentiment in Forums. Download to User Guide and Manual. http://www.retrevo.com/s/HP-2575-Multifunction-Printers-revi... - 85k - Similar pages
Nov 16, 2009 | HP Photosmart 2575 All-In-One InkJet...
Unable to print or scan with HP Photosmart 2575 to new Vista
That means that the printer software installation is corrupted.
You need to reinstall the drivers for this printer.
If you have original printer disk, use the disk to reinstall the printer.
If you have misplaced the disk, then you can download driver from link below:
HP Photosmart 2575 All-in-One Printer
Run installer file after download has finished.
Start driver installation with printer USNB unplugged, the printer setup wizard will tell you when to connect the printer to computer.
Set the printer as default when asked.
Feb 17, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
Error B8387360
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=441248&productBigSeriesOid=441263&spid=441240&pname=HP+Photosmart+2575+All-in-One&opname=HP+Photosmart+2575+All-in-One&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&st=11&ptype=consumer&stype=pn&qry=Error+B8387360&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+Photosmart+2575+All-in-One&cqry=&uqry=
Dec 07, 2007 | HP Photosmart 2575 All-In-One InkJet...
Ben Johnson
