Question about Alcatel Cell Phones
Alcatel 1touch is completely dead and wont charge to turn on. when put on the charger it came with it will vibrate and go to the alcatel1touch screen then a white triangle w/ an xclamation mark inside
  • 94 Answers
SOURCE: Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Posted on Jul 04, 2009
  • 1986 Answers
SOURCE: Warning light
I believe it has to do with your traction control sensors and that one of the sensors may be faulty
Posted on Oct 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: turns off when taken off charger do i need a
You more than likely need a new battery, but try this free fix before you spend anything. Remove the current battery and wipe the metallic battery contacts and the phone contacts firmly with a dry cloth to remove any corrosion that may have built up on them. If you can see a buildup on the contacts (white or greenish deposits) you may need to get more serious with the cleaning (fine wire brush, steel wool, etc.). Once the cleaning is complete, make sure that the inside of the phone is clean of residue, then install and charge the battery. This may or may not work, but a no-cost solution can't be beat. If it doesn't work for you. eBay and BatteriesInAFlash.com are good sources for a replacement battery.
Posted on Dec 01, 2009
SOURCE: Samsung NC10 Screen goes white when plugged into Charge
I too had this problem with my NC10, and i found that on the back, the little slider holding on the battery casing was not in the locked position. As soon as I locked the slider, the problem was solved and has not occurred again.Might not be the case for all these posts above, but worth checking your before having to get involved with customer services etc.
Posted on Jan 12, 2010
  • 122 Answers
SOURCE: Dead P1i; wont power up; wont charge
the bios might need to be flashed. . have it flashed or reformatted by a technician
Posted on Feb 16, 2010
My Alcatel one touch model 5027B wont turn on and when pluged into charger it flashes a red light
Usually when the light flashes you have a dead battery. It should be just a red dot when plugged in check your charger it may be no good.
Jan 25, 2018 | Alcatel Cell Phones
MY ALCATEL ONETOUCH WONT CHARGE I PUT THE CHARGER TO CHARGE AND IT WONT CHARGE AND BATTERIE IS TO DEAD TO TURN ON
Is the battery good? Is the charger putting out the correct voltage or for that matter any voltage, check both.
Nov 04, 2016 | Alcatel Cell Phones
Why doesn't it charge?
Hi Stacey, The links below are youtube videos showing how to fix white screen, CHEERS
Fix for Android Tablet White Screen Issue
white screen on cell phone YouTube
Apr 07, 2016 | Alcatel Cell Phones
How come my straight talk zte cell phone wont turn on?
Two possibilities
  • The battery is not charged and/or completely connected
  • The phone is dead
Try turning it on with the battery in AND with the phone plugged in to the wall charger. If it continues to do the same thing, return or exchange it.
May 13, 2014 | Samsung SPH-M300 Cellular Phone
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
Huawei Premia M931 4G , wont charge or power on at all
I have this phone and it's doing the exact thing! What was the problem?
Jul 11, 2013 | Cell Phones
My phone is not holding a charge. It seems completely dead, and when I try and charge it it flashes sporodically and vibrates for a second or two before dying again
When your phone tries to come on and goes back off after vibrating for a second or two.
This is due to the fact that the battery is completely dead and is trying to pick up when you plugged it to the charger.
Try to charge the battery of your phone in another phone before fixing it back into your phone.
turn it on before trying to charge it again.
make sure the battery never runs out before you charge it back.
take care
Jun 12, 2010 | Sony Ericsson K850i Mobile Phone
My nokia 6220 wont start. When holding down the "on" button it just vibrate a little and the screen lights up a little bit, then it goes back to completely black again
The battery cell may be completely dead and you need to replace the battery. Because its going completely black again means its actually completely of. So try and change the battery, but make sure you charge it till its completely full before usage. Hope that puts a smile on your face.
Oct 13, 2009 | Nokia 6220 classic Smartphone
Wont charge, dead battery
make sure that your charger is not bent, i had the samd roblem sometimes you just have to get a new charger or just get that one to position right so that it will charge the phone
Apr 05, 2009 | LG VOYAGER VX10000 Cellular Phone
Phone wont turn on
THE FIX !
I had the same issue with a Motorola V170, even after fully charged!
The answer is not in the user manual but here is the solution:
1. Put phone on charger in case it really needs charging.
2. AFTER phone is completely charged, and while it is still hooked up to charger, flip open phone and:
hold down the RED button (the call end button, has a phone receiver icon on it)
3. After a couple seconds, phone will now vibrate once and ask for security and unlock codes.
Fix date and time, and you are good to go !
Hope this helps all, worked for me.
Feb 21, 2008 | Cell Phones
Cell Phones Logo
26 people viewed this question
Top Alcatel Cell Phones Experts
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Dakshinamurthy...
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
