Question about The Health & Beauty
How do yo0u remove on the battery on thego go scooter
  • The Master
  • 10,285 Answers
Http://www.pridemobility.com/gogo/models.asp It depends on the model. Go here for more information. If your scooter has a lift off battery enclosure, you remove the screws that hold the top on and gently separate the top so you can remove the wire connections from the battery.
Posted on May 04, 2017
How do I replace batteries on firehawk scooter...can not find access to batteries
Remove the seat. Then remove the plastic cowling. It may be held on with velcro at the corners. Battery is under the cowling.
Sep 16, 2015 | Health & Beauty
Where can I get battery for groovy girl va va Vroom scooter
You need to check what batteries your scooter uses by removing
the cover and reading the information on the side of the battery,
Jan 17, 2015 | Health & Beauty
How do i remove the battery from my go go elite scooter..?
If it is like my Pride Go Go Traveler Elite scooter, what they don\'t tell you is that you need to give the battery a sharp jerk to make it release and come off the scooter. You can\'t just pull it strong and steady.
Apr 26, 2014 | Pride Mobility Products Go-Go Elite...
Battery stuck on Pride mobility scooter
Hi. There are no locking devices on the GoGo Elite Traveller series of scooter. The Battery pack simply lifts off. However, they can be very tight and sometimes require a sharp tug upwards to remove them.
Hope this helps.
Jan 02, 2013 | Pride Health & Beauty
I'm new to scooters. Where would my battery be located on my jonway scooter as I believe I have a flat battery and would like to recharge it
YQou've pposted your Question in "mobility" scooters forum. The vehicle you are posting aboutt uses fuel. Generally we use electricity, Big Batteries. I lookd up your battery. http://www.monsterscooterparts.com/12-volt-ytx7l-bs-scooter-motorcycle-battery.html
Looks like a normal battery, it should be under the seat. Scooters makers somtimes put a storage compartment under the seat. So you must remove one of the side panels.
Jul 11, 2012 | Health & Beauty
Put in new batteries and scooter will not do anything
It could that your potentiomenter is broken and would need to be replaced. simply removed the housings from both sides to get to the throttle part and check to see if the spring is not broken. if it is broken, simply remove old one and buy new one which should be around 60.00 and up in cost. can go to this website to check
http://www.monsterscooterparts.com/mobility-scooter-throttle-pot.html
May 10, 2012 | Shoprider Mobility Products, Inc. Hero...
Can you charge scooter without taking the batteries out? Is there an exterior spot to plug in?
You can charge the batteries with your offboard charger and the battery pack still on the scooter just plug the charger into the charger port on the side of the battery case and then plug it into the wall socket and charge overnite Will work just like if you removed the battery pack from the scooter. Hopw this helps you
Mar 26, 2011 | Pride Value Line Revo Scooter 3 Wheel
Have a Panther Scooter and we want to replace the battery, how do we get to the old one.
Jean you have to remove the seat then the rear shroud and you will find the two batteries strapped into the frame disconnect the battery cables from the wiring harness and lift the batteries out of the scooter remove the cables from the old batteries and reinstall the cables paying attention thast you connect them like they were on the old abtteries ie red to positive posts and black to negative posts. Reinstall into the scooter strap down and turn the scooter on to make sure that you have power. If everything works correctly reinstall the shroud and the seat then charge the batteries before use and you should be good to go Charge the batteries every night and they should last a good while Hope this helps you
Mar 16, 2011 | Invacare Supply Group Invacare Scooter...
I need to find a stackable battery box for my scooter, as well as what batteries are needed. Also, what charger should be used with it? I bought used from a private party-no charger and the small battery...
James your scooter use 2 12-12ah batteries located inside the battery case. Just remove the screws holding the case together and remove the old batteries then replace with the new ones making sure that you repace the wiring just as you removed them from the old batteries you might also have a heat sensor attached to one of the batteries make sure you reattach that to the new batteries. Any off board charger made for power chairs or scooters will work but try to find a 4 amp charger with an on/off switch. Always turn the charger off when plugging or unplugging from the scooter Check on e-bay or with a provider for a charger Hope this helps
Nov 18, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Feb 13, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Health & Beauty Logo
Top The Health & Beauty Experts
Don A
Don A
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
