Question about D-Link AirPlus DI-524 Wireless Router
D link D524. No range.
D link D524. Used to get good range, now only gives 2m range. How to fix?
    Genius:
  • 1,268 Answers
You need to change the Wireless Channel on your wireless router. Open the router's setup page by going to http://192.168.0.1. It will prompt you for username and password. By default username is admin and password is password or no password. When you have the router's setup page opened, look for wireless tab and look for Wireless Channel. You must change it to 11 or 6 or 1 then save the settings. You can play around with the channel and find out which one gives you better signal. If you're still having low signal range, try to reset the router back to factory defaults by pressing the reset button at the back of the router for 30 seconds and do a power cycle. Just reconfigure the router after resetting it.
Posted on Jul 25, 2009
The ratio of men to women on a bus is 4:5 Nobody gets off the bus. 18 more women get on. The ratio of men to women is now 1:2 How many men are on the bus?
m = men
w = women
equation 1
m/w = 4/5
w(m/w) = w(4/5)
m = 4/5w
5(m) = 5(4/5w)
5m = 4w
w = 5/4m
equation 2
m/(w + 18) = 1/2
(w + 18)(m/w + 18) = (w + 18)(1/2)
m = w/2 + 9
2m = w + 18
w = 2m - 18
Substitute equation in equation 2
w = 5/4m
5/4m = 2m -18
4(5/4m) = 4(2m-18)
5m = 8m - 72 multiply by -1
3m = 72
m = 24
solve for w
w = 5/4m
w = 5(24)/4
w = 5 * 6
w = 30 m = 24
Jun 05, 2017 | The Computers & Internet
Yamaha np 32 some keys faint in response
This is normally caused by dirty or worn contacts.
Simply open up the keyboard and replace the contact rubbers when the sensitivity has been lost.
There are 4 different rubber contacts depending on which notes are not working
WJ231101 RUBBER CONTACT 16N-2M OCT 2M-55
WJ231200 RUBBER CONTACT 16N-2M OCT 2M-45
WJ231301 RUBBER CONTACT 16N-2M 76H 2M-45
WJ231401 RUBBER CONTACT 16N-2M 76L 2M-55
Nov 12, 2016 | Yamaha Music
How to set GDT-311 Digital Multimeter to x 1000 ohm setting?
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.
Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value.
I hope this helps!
Apr 12, 2012 | Gardner Bender Measuring Tools & Sensors
Focus stack if you rotating it from infinity to 1.5m at ~6m and did not go to 1.5m it's only can be used in this range
Some zoom lenses have a focus lockout at certain zoom ranges. I'd be highly doubtful it'd be at 6m, but that's just a thought. For example, they may not be able to focus below 2m at the 100mm setting, so the focus locks out at that point at that setting.
I'd be looking for a shop, or contacting Nikon for a service center to take a look at it, and certainly don't try to force it less you risk doing further damage. Lens repairs can be tricky, so if it's a newer lens I'd leave it up to a Nikon center unless you've got a shop you've used before and trust.
Has the lens been dropped, bumped, damp, wet, in humid conditions, hot (over 90 or so F prolonged), extremely cold prolonged, in corrosive environments (acid or seawater nearby), etc?
Sep 11, 2011 | Nikon AF-S Zoom Nikkor 80-200mm f/2.8D...
I need a bulb for this light. Can't seem to find one
It is a common 12 volt bulb used in most driving/fog lamps and can be purchased at your local Wal*Mart or auto parts store. Remove the old one and take it with you.
Good Luck!
Jul 20, 2010 | Vector 2M Pwr Rch Spotlight
Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Jul 26, 2009 | Foxconn Computers & Internet
12+2m=20-2m
12 + 2m = 20 - 2m
2m + 2m = 20 - 12
4m = 8
m = 8/4
m=2
Mar 06, 2009 | SoftMath Algebrator - Algebra Homework...
Change format of shots from 1M to 2m,3m etc
You can download the manual from the link below: http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S5000Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 01, 2007 | Fuji FinePix S5000 Digital Camera
NetRAID-2M hangs out while initializing HDDs
Here's a link to the fireware update tool you need to do the flash: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=329290&prodSeriesId=65146&swItem=ns-9915-1&prodNameId=19319&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0 As for never getting the chance to boot from the floppy drive to update the drives, try using the ServeRAID controller just to flash the drives then put the NetRAID-2M controller back in.
Jan 30, 2006 | HP NetRAID-2M SCSI Controller
D-Link AirPlus DI-524 Wireless Router Logo
111 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
