How to solve this ec-556 error - Computers & Internet
Ricoh sp 210 printer showing error sc 556
Make a phone call to your Ricoh service rep and report code SC 556.
Mar 27, 2018 | Ricoh Office Equipment & Supplies
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
Error code 556
The 556 error means that the rear fusing unit temperature sensor has shown a 50 degree C (or greater) change within one second. The unstable temperature issue has occurred twice. There are a few causes. Since you said that there was a brief power outage, the most likely is that the Aficio 2015 power supply unit has failed. The other possibilities is that the thermistor (the temperature sensor) is bad or out of position.
You'll need to contact Ricoh for service to resolve the problem. If you have a service contract for the MFP, contact that provider.
I hope this helps.
Aug 05, 2014 | Ricoh - AFICIO 2015 Printer
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
How can I solve a service 12 error
Call Service 12 means that the color motor rotation detection signal (LD) does not go Low.
After the LCD indicates this error turn the power off/on & perform the motor test by pressing the MENU, #, 9000, *556 and press 2 & set buttons. See if this helps you with this issue.
May 24, 2014 | Panasonic DP-MC210 Color Copier
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes. rinnai.us, look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
EC/KBC Damaged
This can mean only one of two possible things. Either the [Tab] key on your computer is stuck, or your system needs to be serviced
First, turn the computer off. If the cause is a stuck [Tab] key, you may be able to un-stick it by tapping the [Tab] key several times. Turn the computer back on. If you don't see the error, congratulations, you fixed a stuck [Tab] key. If you do see the error message, you should contact a Toshiba Authorized Service Provider and have the system serviced
May 05, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
