Question about Hoover Vacuums
How to work my hoover model r5906-900 - Hoover Vacuums
U4771-900 doesn't work... How do I open it up to see if the belt is broken?
I'm not familiar with this model number that you have given. Is your vacuum a Hoover model? If so you can get any Hoover belt here:
Replacement Hoover Belts
Nov 06, 2009 | Vacuums
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Where can I get a manual on my model#F5817 steam
Here is a number for customer service for Hoover.
contact our customer service department at 1-800-944-9200 M-F 8 AM - 7 PM EST.
I went to their website and searched for a manual. Some of the manuals will cover more then one model so they will have to tell you which one will work for you. Hope this helps
Aug 15, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Need a front wheel assembly for my Hoover Tempo model u5144-900. I see similar looking Hoover wheel assemblies online for different models, will they fit mine?
The Tempo series cleaners look similar, but are different colors. The wheel assemblies will work if they look identical in appearance to yours.
Aug 07, 2009 | Hoover U5144900 / U5146900 / U5147900...
Can't find belt# 38528-040-A2 for my upright Hoover Model U5134-911. Is there a another belt that would work for this model?
The Hoover belt number is 38528040 for the single belt. Sold in a 2 pack of 40201190. look for the 2 pk number. use only Hoover belts, they will perform better.
Feb 28, 2009 | Hoover U5134-900 Bagged Upright Vacuum
Can't get bottom plate off hoover model
Am a bit confused because I can't find the model number you give on the Hoover website, so am not sure exactly which machine we're dealing with. However, the procedure for removing the bottom plate is common to most self-propelled upright wind-tunnel models, and it's simply a matter of laying the machine flat, turning it over and removing the four recessed screws that hold it in place. It can then just be lifted off. If this doesn't work for you, perhaps you could confirm the model number and I'll try again. It will also help if you say what country you're in. Good luck!
Feb 26, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
