Question about Roomba Vacuums
Roomba 880 will not find dock and passes vertual walls too when i place it and duck it will change perfect.
bobfiala
  • 28 Answers
SOURCE: Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Posted on Nov 14, 2008
  • 8 Answers
SOURCE: My Roomba 560 does not automatically dock as advertised either..
You may not believe this, but the new 500 series lighthouse virtual walls have both infrared and radio frequency communication. How they work and associate with the Roomba is pretty complicated. The best posting I've ever seen about how they work is here:
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=11048
Check out that link to understand how the communication works.
If your Roomba is contained by the virtual walls, then you can assume the IR sensor on your Roomba us good....you should test that though. Then you might have to replace the "home base" which could have a bad IR transponder . New ones can be found for reasonable price at www.RoboticVacParts.com or you could order straight from iRobot for twice the price.
If the Roomba is not contained by the virtual walls, then the IR sensor on the Roomba is likely bad and you'll need to change the bumper on your Roomba. Again ....parts are available through ebay, or www.RoboticVacParts.com. Follow this link if you need it.
http://cgi.ebay.com/NEW-Roomba-500-series-white-bumper-510-530-532_W0QQitemZ270400281066QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef51cd9ea&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Posted on Jun 20, 2009
  • 58 Answers
SOURCE: roomba 560: it only spins in one place, then stops
If there's no message its probably a sensor malfunctioning. It might be a cliff sensor, the bump switch, or wheel-drop (left, right, or caster). Try cleaning the sensors and vacuuming things out as a first step.
Posted on Dec 13, 2009
SOURCE: My Roomba does not want to dock
Need more info.
Does the unit go into search mode? "SPOT & CLEAN" flashing? It actually tries to search?
Do you have another roomba to test your dock on to see if IT will dock? If it tries but just cant, then either the dock transmitter, or the roombas receiver is dead. (The round antennae thingys on the dock and the bumper) replace these would be the first point.
Posted on Jul 24, 2010
  • 3 Answers
SOURCE: roomba stopped after 45 minutes. does not move.
Sounds like something's dead either with the roomba or the charging station or power supply. Does it charge up if you plug the power supply directly into the roomba, instead of into the charging station? If not, you'll probably have to return it to the place you bought it.
Posted on Sep 17, 2010
I have roomba 880 stationed in open w/nothing blocking view (virtual walls, lighthouse, doors, etc) but it will not go back to docking station even when I press docking and its only 6 feet away.
it seems as if the robotic cleaner is having a problem sensing where it is or failing to notice where its charging station is try cleaning any optical/IR sensors and it maybe able to see once again where its charging dock is
Jan 06, 2017 | Roomba Vacuums
No power to docking station, no lights
check the warranty period and if still under warranty , take it back for a warranty check
Sep 18, 2016 | iRobot Roomba 880 Vacuum Cleaning Robot
I roomba wont dock
That's usually caused by a charging issue. Could be that the contacts the roomba uses to charge on the base are bad or the contacts on the roomba its self. Here is a good troubleshooting guide. Roomba customer service is very good too, if the roomba is less than a year old they will repair it for you. good luck!
Jul 19, 2013 | Vacuums
Roomba stopped after 45 minutes. does not move. manually placed on docking station...nothing
Aug 27, 2010 | iRobot Roomba 560 Robotic Vacuum
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba Battery (existing and brand new one) Not holding a charge.
The Charging circuit on the main board is dead. Either replace the main board or repair it if you have the skills and equipment.
Jan 06, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Jun 18, 2009 | Roomba Robotic Floor Bagless Vacuum
Light houses aren't turning on.
Make sure your virtual wall batteries are fresh-- even if you're sure they are, try removing and replacing them just to reset the virtual wall.
Then reset your Roomba: hold down "spot" and "dock/demo" for about fifteen seconds. Release them and wait for the tune.
Recharge the Roomba and then try to run it. The virtual walls ought to respond at that point. If they don't, you might find that calling customer support may help.
Apr 06, 2009 | iRobot Roomba 550 Vacuum
Need more info.
Jan 21, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
43 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
