Question about Frigidaire Washing Machines
This there a code to reset Frigidaire front loader because E61 code is appearing?
IFIXALL
  • 868 Answers
SOURCE: (Partial, intermittent) Fill after final spin: Frigidaire front loader
Replace the water valve and your problem is gone.
Posted on May 21, 2008
  • 1314 Answers
SOURCE: frididaire front loader problem
send me an e mail at b4829@yahoo.com
Posted on Jun 17, 2008
SOURCE: front loader dryer
Sounds like you have a broken belt. I had the same problem and replaced it myself. If you have someone handy at home, there are detailed instructions on the internet (just search) for replacing dryer belts for your model. That's what I did. A new belt costs about $13. If you need to call a service man in to replace, it might cost between $100 - $200.
Posted on Oct 27, 2008
  • 378 Answers
SOURCE: Frigidaire Front loader nightmare!
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Apr 03, 2009
  • 574 Answers
SOURCE: Frigidaire affinity front load dryer e61 code. Replaced the control board and display board. Still have the same problem e61. How do you check heater relays?
ther is a thermocouple next to heater elements , check continuity of elements and thermocouple
Posted on Mar 22, 2012
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
Front loader. Why does it run for about 30 seconds, then stops, beeps, and displays code e64?
Good Morning friend, thank you for your post!
I see that your Frigidaire frontload washer runs for 30 seconds, then stops, and produces an error code "E64". It appears that might be an invalid error code. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If you continue to receive the error code or a new error code please reply back. I would like to assist you further. -Matt
Jun 04, 2015 | Frigidaire Washing Machines
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
I have a Frigidaire Front Load Washer (FAFW3801LW) that is registering an error code and continuously beeps on and off at random times. I held the start/cancel buttons and E61 or Eb1 popped up. I assumed...
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Frigidaire Washing Machines
What does Frigidaire affinity dryer code E61 mean
E61 is a line voltage problem, most of the time it means you have the neutral and the L2 wire either reversed or in the wrong position. Verify that the voltage is correct at the plug then at the machine and that you have 240 volts at the terminal block on the back of your dryer.
Oct 18, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
