Question about Royal Office Equipment & Supplies
I have a Royal Signet 20 that won't advance the ribbon after typing 1 letter.
  • 478 Answers
SOURCE: adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Posted on Oct 19, 2007
  • 3594 Answers
SOURCE: Ribbon will not advance fully
If I remember correctly Code + comma (,) It may be the period(.) or slash(/) one of these should change the ribbon advance.
Posted on Dec 10, 2008
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Posted on Jan 27, 2009
  • 3594 Answers
SOURCE: IBM Selectric II Ribbon Not Advancing
First check to be sure that the ribbon is on the left of the shock wire where it comes out of the cassette, if that is OK then check the ribbon driver it should move freely and swing to the ribbon take up spool. Some WD40 will free it up. Also be sire the ribbon is winding in the direction of the arrows.
Posted on Jun 16, 2009
  • 3594 Answers
SOURCE: Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
Posted on Aug 03, 2009
Royal safari portable typewriter letters ghosting
Usually you are striking incorrectly snap the keys and get off of them. you holding the key down too long.
Jun 28, 2016 | Royal 1966 Safari Portable Typewriter 8247
What are all the Codes for the Royal Signet 10?
Usually they are highlighted on the key tops and you have to use a function key to access that action.
Apr 30, 2014 | Office Equipment & Supplies
My Dad has a Royal TA memory typewriter. He tells me it is typing every other letter. It's not double spacing his's skipping every other letter. He also says it's making a clickity clack...
It sounds like the ribbon is twisted and interfearing with the P/W Try installing a new ribbon and check the P/W for bent or broken spokes.
Mar 11, 2011 | Royal PowerWriter Typewriter
I have a Royal Signet 25 Typewriter that works fine, except that the type is uneven and some letters come out very light, others are fine. I think it may just need cleaned and adjusted, maybe? Any...
It might be a ribbon problem. take the ribbon cassette out and look at where it has been typed on. Do the characters overlap? If so, get a new one. Or the ribbon might be dried out. Is there an impression control? Set it on heavier print. If you have a different print wheel, try that too.
Feb 09, 2011 | Royal Office Equipment & Supplies
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
Feb 17, 2010 | Royal Office Equipment & Supplies
The keys on the left side of my circa 1933 Royal typewriter gets stuck on the ribbon everytime. Also my ribbon doesn't advance. Help?!
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Jun 28, 2009 | Royal ET510 Typewriter
How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
May 31, 2009 | Royal Office Equipment & Supplies
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
