Question about Samsung Office Equipment & Supplies
Card jammed right inside my samsung CLX3305 MFP how can I get inside printer to clear it
5 Suggested Answers
CAM THE MAN
  • 20 Answers
SOURCE: paper jam
First thing i would try would be turning the machine upside down and shaking it gently, might have something lodged inside.
Second I would place fingers down the back of the printer where the paper feed is and rotate the felt rollers that feed the paper through.
Third to see if the paper sensor are not broken or jammed.
Hope this helps you
Posted on May 27, 2008
  • 1218 Answers
SOURCE: HP 5510 says clear paper jam. There is no jam
verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Oct 14, 2010
Testimonial: "I haven't tried it yet because it is no longer hooked up but I will. Thank you for your input."
hattinghbr
  • 214 Answers
SOURCE: Hi I have a Samsung SCX 4521F printer. It had paper jam in automatick document feeder. All of the paper has been cleared out.
YOU will to open it. there is two sensors. check if bouth are loos
Posted on Nov 04, 2011
TechyDrood
  • 2072 Answers
SOURCE: Brother printer clear non-existant paper jam
There probably is one or a sensor is dirty would be the most likely culprits.
Posted on Jul 10, 2012
Paper jam message appears in initial setup of new printer and won't clear
If no paper used or jammed, next thing see that menu says , to help clear your problem.
Mar 16, 2015 | Canon MF6160DW - MFP - LASER PRINTER -...
Error 30.01.02 before and after change of scannertop
30.1.2= A jam has occurred in the ADF. Recommend action, turn the MFP off and then back on to try to clear the message.
If the message indicates that a jam has occurred, clear the jam, if the message is still there. Check that the cable between the print engine and the scanner is secure..
Turn the MFP off, remove all memory DIMMS or third party DIMM from the MFP (Do not remove the firmware DIMM) remove all EIO device from the MFP. Turn the MFP on
if the erropr no longer exists, reinstall each DIMM and EIO device one at a time, make sure to turn the MFP off and no again as you install each device. replaced a DIMM
or EIO device if it cause the error, if problem persists upgrade the firmware before replaced the DC controller. Replaced the formatter and calibrate the MFP.
take a look here
http://h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-420/34967/1/357783.pdf
Mar 31, 2014 | HP LaserJet 4730 MFP Printer
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
HP LASERJET 100 COLOR MFP M175a PAPER JAM
I suggest you some points like clear the dust in the printer, proper set paper in paper place, adjust the paper line etc..
If More Support visit this link. I hope solved you problem..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02622145&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=5076465
Jan 15, 2014 | HP LaserJet Pro 100 color MFP M175A Laser...
Tenngo un printer samsung clx3305-fw y quiero conectarlo a un laptop asus
u will need a usb cable or a ethernet cable to connect it. you first need to install the driver of the printer on the laptop and that should be a cd that you got with the printer. as soon as the driver and software is on the laptop, u can connect the printer and it should work.
Nov 11, 2013 | HP LaserJet P4015N Printer
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Jam is in the back door area..paper tore off inside...is there anyway to take out top section inside the back door to clear?
There is, but best done in a shop. You remove the back cover, 4 screws, and the fuser is held in by another 4 screws. The fuser has to be aligned to gears on the right, and a spring loaded connector on the top left to be removed. You also have to remove the right cover and unplug the 2 cables to the fuser to get enough room to clear the jam.
Apr 20, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
