Question about Refrigerators
Refrigerator I leaned on key pad. reads cooling off.I can notchang it. what to push
How to turn off cooling off light off. My child was leaning against the fridge for a while when stood up straight I saw the cooling off light was on.
Check your user manual, but for my whirlpool it says: If the buttons are inside the fridge, push the FAST COOL and MOISTURE CONTROL buttons at the same time for 3 seconds. Once cooling comes back on, your previous settings will reappear on the display. If the buttons are on the outside of the fridge (as mine are), push the FREEZER TEMP and FRIDGE TEMP buttons at the same time for 3 seconds. Same result as above. Hope that helps.
Nov 01, 2013 | Whirlpool GZ25FSRXYY ENERGY STAR Qualified...
Can I lean my fridge back to clean coils underneath? I am experiencing fridge not getting cool air . The freezer is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 14, 2011 | Kenmore Side by Side Refrigerator
Sub-zero 690/J 20 yrs old, compressor burned out friend's son is apprentice reefer mech he replaced compressor cut and reconnected only discharge and...
ASK HIM TO LEAN THE OIL BY FLUSHING AND PUT THE ANTIMOIST,EVEN THERE MAY BE EAKAGE ON THE JOINTS.DID HE CHANGED THE FILTER BEAUSE IT IS NESSASARY TO CHANGE.CHECK IF THERE IS BLOCKAGE IN CAPPILARY
Nov 17, 2010 | Sub-Zero 690 Side by Side Refrigerator
Just stopped cooling and all the function of of key pad don't wor
you will need to replace the main board located on the rear panel behind a cover as this board operates all facets of the unit
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My stove reads F1 and I push the cancel pad to
f1 indicates a faulty erc electronic range control or a stuck key pad. First check the keypad by pressing each button one at a time. You should hear a click and feel it fully retract. If it does not replace the keypad. If the keypad is working properly the erc will need to be replaced. Here is a link that should help with this problem http://appliancehelponline.com/ovenerc.html
Jul 15, 2010 | Kenmore Ovens
HI, I HAVE A ROBINNAIR 34134Z AC UNIT. I AM NOT ABLE TO ADD 134 TO SYSTEM PUSHING KEY PAD ARROW UP. POUNDS REMAIN AT 0.0. ON ALL OTHER FUNCTIONS, KEY PAD WORKS FINE.( UP--DOWN). REMOVED COVER, REMOVED AND...
Please try the following: 1# Verify the ISV (tank) dose not have excessive pressure.note the tank's temperature & pressure readings and compare to pressure chart on unit.purge excess air if necessary.the refrigerant may be contaminated and should be handled appropriately.
2# Press recover & verify the Recovery solenoid (S1) is receiving power & opening properly.
If not receiving power check continuity of the wiring between solenoid & circuit board,repair as needed.
If the wiring is correct and no power is being applied to the solenoid,replace the circuit board.hope this will help you.
Jan 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
Our GE upright freezer door keeps opening on its own! Our food is starting to melt and the manual only talks about tightening the refrigerator door. What should i do?
Your refrigerator is leaning forward to far and you need to adjust the front legs so that it is slightly leaning back. This is why the doors are opening as they work by gravity. On the bottom left and right front corners of your refrigerator you should round pads with threaded legs screwed it the bottom of your refrigerator. You need to lean the unit back and adjust these out to raise the front of your refrigerator until the doors when opened will slowly shut on its own. A level comes in handy for leveling also.
Oct 09, 2009 | GE Refrigerators
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Water filter light
to reset. hold dispense light and lock key pads on the dispenser control panel pushed in for 3 seconds until light flashes. This will reset it
Please rate me.
Apr 14, 2008 | Jenn-Air JCD2389G Side by Side...
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
