Question about Dryers
Getting an E61 code on dryer, have not ever had problems, help
4 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
  • 548 Answers
SOURCE: Frigidaire affinity front load dryer e61 code. Replaced the control board and display board. Still have the same problem e61. How do you check heater relays?
ther is a thermocouple next to heater elements , check continuity of elements and thermocouple
Posted on Mar 22, 2012
richroth
  • 9472 Answers
SOURCE: replaced control board on dryer still getting e61 code
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Posted on Nov 18, 2012
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Mar 28, 2016 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
I have a GE dryer and it's reading the code E61 what does that mean
For GE dryers, the E61 code indicates a problem with the wiring or the control board. The dryer is sensing the wrong voltage between the hot and neutral lines of the incoming wiring. First check your wiring/fuses/circuit breakers. If your wiring is OK, then the control board is probably faulty.
If you post a comment with the model, I may be able to point you to the appropriate parts. I hope this helps.
(note: if you have an electric dryer using 220V, you may want an electrician to check the wiring.)
Apr 25, 2015 | GE Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
I am getting E61 code on my Frigidaire Affinity Dryer model number FASE7073NA, how do I clear this error code?
Good Morning Friend, thank you for your post!
An error code E61 on your Frigidaire dryer is associated with a failure in the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
May 27, 2014 | Dryers
Replaced control board on dryer still getting e61 code
Nov 17, 2012 | Frigidaire Electric Dryer
Error E61 appears on digital screen. dryer does
I was told it was main computer board. Ours got the code when we had power surge.. Not sure how yours happen
Nov 17, 2009 | GE DCVH515GF Gas Dryer
Sep 25, 2009 | Electrolux EIED55H Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
