Question about Garden
YT 48XLS tractor starts, runs for about 3 seconds and then stops like the key is turned off. I have been using the tractor, just stopped in the middle of moving the lawn. Any suggestion?
    Habit-Forming:
  • 60 Answers
Could also be a faulty seat safety switch if your tractor has one.
Posted on May 02, 2017
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Sounds like the needle valve in the carb just got hung up.
Tap on the carb bowl a few times it may shake the Valve loose.
Tassimo. Why do descaling light and water light turn on in the middle of brewing, then machine stops?
fill it with clr and run it 2 times,then run it with fresh water each time 2x to rinse it,save the clr it is still good,use a water filter on the water
Jul 13, 2015 | Coffee Makers & Espresso Machines
My YT model 28857 24hp engine Lawn Tractor runs rough and surges up and down when at idle. I just bought this tractor, 8-8-2011 Is there a carburetor adjustment to smooth out the engine idle? Will this...
The carburetor is most likely dirty and needs cleaned. Dirt can get in there from the gas can. Check the fuel tank. Is this a new mower? If not check the air filter, it will also cause this to occur if it is stopped up.
I hope this helps get you running again.
Aug 10, 2011 | Garden
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
The engine will start and run for 5 seconds and stop.I have fuel to the fuel filter.
You have a fuel problem most likely a block in the carby. If it runs with the choke partially on this will verify the cause
Apr 07, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Mower runs in choke, but when lever is pulled down to run it stops.
The gas flow is restricted, probably due to gummed up fuel. First be sure the gas shutoff valve is all of the way open (it only turns 1/4 turn). If there is a fuel filter replace it. If that doesn't fix it, drain the gas and replace with a small amount of fresh gas and carb cleaner (about 2 to 1, 1/4 cup total). Run the engine on that. You might have to repeat a time or two. If that doesn't fix it, you will have to take the bowl off of the carb and clean the float valve and the needle (mixing) valve. To minimize this problem in the future, use a gas stabilizer like Sea Foam or similar. Good luck.
Aug 11, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
My yamaha yt 3600 tractor wont stay running, I turn on the key, full tthe float bowl, it will run for 30 seconds then stop, is it the fuel pump or a relay, or an other electric problem
The fuel pump is an expensive little devil. Try the simplest thing first - check the fuel filter. Just remove the spring clamp or band clamp and pull off the hoses. If that's OK, you should check the pump. You might be able to feel it buzzing, but that doesn't guarantee it's working, so remove the hose between the fuel filter and engine, point it toward a bucket, and see if you have pressure when you crank the engine. Good luck!
Jun 10, 2010 | Garden
20 HP Craftsman lawn tractor starts easily, but only runs
This is classic dirty gas filter ... I dont say that is all it could be ... but is it classic dirty filter. You might have something in the tank that is blocking gas getting out of the tank.
check it out ...
Oct 20, 2009 | Garden
I was using my Bolens riding mower and stopped to put gas in. When I tried to start it, it clicked but wouldn't start, then it stopped clicking when I turn the key, now it does nothing when I try to start...
sounds like to me that your flywheel key is jammed. you will half to take it apart. Inside you will see a little gear on top of a cylinder shape object. and the gear turns the middle part. you will have to turn the middle part as hard as you can to get the gears unjammed.
Jun 15, 2009 | Briggs & Stratton Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
