Question about Lands Phones
Key pad. I LEANED ON IT AND NOW IT READS COOLING OFF i CAN NOT MAKE IT CHANGE oFF FOR HOUR
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
The item is a technika cr-109ip ipod docking station and clock radio but it has not come with and instruction manual and we cannot figure out how to change the time, the alarm time can change but not the...
1)touch and hold both the M and E touch pads for at least 1 second to enter clock setting mode- the hour digits will now flash
2)set/change the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the hour digit
3)when the hour is set correctly touch the E touch pad to confirm
4)the minute digit will now flash. Set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
5) when the minutes are set correctly touch the E touch pad to confirm
the clock is now set
Dec 25, 2010 | Audio Players & Recorders
Solid state water chiller thermotek T252P-4 , how do I adjust cooling rate per minute
That's the gradient setting. Press the output temp key until gradient appears, then use the up and down keys to change the setting. The change rate is in degs C per hour.
May 11, 2010 | Computers & Internet
Key pad stuck
SHUT THE BREAKER OFF TO THE OVEN FOR AN HOUR, THAT WILL RESET THE OVEN CONTROLS
Nov 11, 2009 | Ovens
Toshiba satellite A45-S2501 keeps turning off after about an hour
just got A75 toshiba and was having same problem.. put it on cooling pad for laptops and seems to solve problem..most people think laptops are designed to use on their lap..the cooling system has to have plenty of room to do it`s job. unit should be used on hard surface and some need assistance from cooling pad, look for one on Ebay.
Apr 28, 2009 | Toshiba Satellite A75-S1253 Notebook
Change default ptr setting for lexmark x8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
How to set the time on our phone
Follow the instructions listed below. You shouldn't have any problems
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date
Mar 13, 2009 | Nortel T7316E 2-Line Corded Phone
How to change time on my T7316E Nortel phone
Step 1
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
Zelco Bookmark dictionary II cannot change clock to from AM to PM
Are you in the 12 hour or 24 hour format?
Start here:
-Press the little clock icon (it's above the letter "Q")
-Press the "A" key to toggle between 12 and 24 hour mode. Sometimes I have to do it a couple times to make sure I know exactly which mode it's in.
-Press the "Space" key to enter time setting mode.
- Use your number pad to enter the time...
- Press "ENTER" key to confirm. It will then take you to the Date Setting Mode. If your date is already set just press "ENTER" again.
I think that should help. If not, let me know.
Please rate as a FIX YA if I helped. ;-)
Feb 01, 2009 | Zelco 90112 Bookmark Dictionary II
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
