Question about Frigidaire Washing Machines
E61 code for a Frigidaire affinity need to reset, not new code just started today
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
SOURCE: frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
Posted on Sep 27, 2008
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
  • 240 Answers
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Posted on Jul 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: my affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Posted on Sep 27, 2010
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Mar 28, 2016 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
I am getting E61 code on my Frigidaire Affinity Dryer model number FASE7073NA, how do I clear this error code?
Good Morning Friend, thank you for your post!
An error code E61 on your Frigidaire dryer is associated with a failure in the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
May 27, 2014 | Dryers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
One error code after another
This dryer uses the triple element heater unit, these new heater resistance strings are thinner in wire gauge size and tend to burn out easily, you will need to do a continuity test for each element string. Pleazer Appliance...
Apr 05, 2014 | Frigidaire Affinity FASE7073NW
What does Frigidaire affinity dryer code E61 mean
E61 is a line voltage problem, most of the time it means you have the neutral and the L2 wire either reversed or in the wrong position. Verify that the voltage is correct at the plug then at the machine and that you have 240 volts at the terminal block on the back of your dryer.
Oct 18, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
