Question about Cell Phones
How do you stop the tracking or tracing - Cell Phones
I need help to track a stolen phone
if the phone trace is not on the phone , not much can be done
call your service provider and put a stop on the account
Apr 01, 2017 | Cell Phones
How can i track other phone
I use CM Security - for alot of things including tracking. I love it and its a very simple interface. Hoever, the other person can tell you are trying to locate the phone if they are paying attention.
Feb 02, 2015 | Cell Phones
Can i trace my iphone 5 with imi as it has been stolen
nope, the imi can be changed in the phone so its not of any use other than activating the phone, track my iphone through apple might if you had that service on, other than that tracking phones like that is of little use as it hardly ever works
Jan 29, 2015 | Apple iPhone 5
My cell phone is being traced. Hew can I undo the trace & prevent it from happening in the future??
1: Choose E911 in the location menu on your phone. 2: Uninstall any tracking apps or programs on your phone. 3: look under your battery and see if there is anything there that difn't come with the phone or that you didn't put there yoursel. If this doesn't work then the only way to completely stop it is to remove your battery and I'm sure you don't want to do that.. So if it doesn't stop after doing the things that I have listed then contact your phone carrier for assistance. Hope this helps
May 11, 2013 | Cell Phones
Usb connector broke off
The + and - are the 2 outside pads on the USB plugs, one will be a thicker track than the rest and should be +5 volts, the other side will of course be 'ground' and is normally the broad copper strips on the pcb that go all the way round. If you're lucky it's a single layer double-sided PCB and the + and - connections may be on opposite sides of the board, if you're unlucky it's a multi-layer PCB that has extra tracks underneath the visible ones, they are impossible to repair i'm afraid. If you have a multimeter it's much easier to trace the power tracks, just don't short anything with the probes, choose a part of the track that's not too crowded.Switch on, locate the + and - and mark them with black & red markers, then switch off asap.
Always touch something earthed like a radiator etc before handling the pcb, this minimises static damage. Hope this helps, good luck!
Apr 23, 2017 | Computers & Internet
How do i remove the 'trace changes' in a word document?
What version is your office? you can remove the "trace changes" on the review tab > click the track changes and click again the track changes. Hope this will help
Jul 11, 2011 | Computers & Internet
You machine have complaint in its main board. Years back i got a machine with same complaint. After a lot of serch i found a track break it its main board, because of some sort of chemical reaction it the tracks. Search for the same in your machine. Just trace the two tracks from the power on switch. One end of it will be common connection for all the other switches And the other end of the power on switch will goto the power supply. As a multlayer pcb it will be very difficult to trace the track. Anyway just try it. Also check the SMD (surface ***** device) fuses in the power supply stage. Also check the power stage for any track break. If you are not able to do this then there is only one way contact the manufacture for support. It will be very expensive because they will tell you to replace the main board.
Jun 08, 2011 | Schiller Cardiovit At 1 Ecg Machine
I lost my cell phone how may i track it down
it can be traced by your Mobile Service Provider like AT&T or Wt ever but you must pay high ,, that would cost more than your phone,
Because only FBI or Crime Investigator would needed this type of tracking
It can be done and tracked even if cell phone is switched off
Sep 10, 2009 | Motorola Mobility RAZR V3
Revox B225 numeric key pad does not allow direcyt track access
That rep is crazy, don't retire it. The copper traces under the keypad are simply oxidized. This is common after many years. They can be cleaned and will work like new. You have to remove the faceplate, unscrew the keypad from the back of it and then you will see the traces. Simply take a pen or pencil eraser and rub it firmly across all of the copper traces. You might as well do both sides while you have it apart. You will notice them shine right up when using the eraser. Reassemble and it will work fine. Email me at if you have any other questions or need any further clarification on this.
Mar 28, 2009 | Audio Players & Recorders
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
