Question about Garmin GPS
My garmin will not turn on - Garmin GPS
    Scholar:
  • Garmin Expert
  • 186 Answers
Connect your GPS to a high output usb charger, i.e. 2A or greater. Leave it overnight charging. If it does not turn on the next day, you probably need a new battery. Amazon sells battery kits.
Posted on May 02, 2017
Just bought a garmin drive 50 changed the language and the turned it off tried to turn it on and it wont switch on
Install Garmin Express from Garmin. Plug your GPS into your computer. Your GPS should turn on into usb mode and Garmin Express should identify it and show you any updates available. If the GPS does not turn on when you plug it into your PC, then contact Garmin for warranty work.
Apr 05, 2017 | Garmin GPS
I have a nuvi 265w garmin. It turns on and then turns off without loading the map
The GPS battery may need to be charged.
Does the GPS turn on when connected to a vehicle power cable?
Running the Garmin WebUpdater to load or reload the latest software will usually fix any bugs.
Contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 23, 2012 | Garmin Nuvi 265W GPS Receiver
I have a garmin nuvi sat nav which is just over a year old when unit is turned on all that shows on screen is the name garmin loading maps flashing on and off
Did you try a reset. Turn off the unit. Hold the bottom right side of the screen and turn the GPS back on. It will make you confirm you want to reset. It will clear out all you favorites etc.. so copy them first if needed. Then I would go to the Garmin site a register and update the unit. See if this works
I will attach Garmins contact info. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 15, 2011 | Garmin Nuvi 265W GPS Receiver
When turning on the unit, it starts up with the Ga...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
THE UNIT WILL NOT TURN ON
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do I turn off our garmin nuvi?
Reset button behind the Antenna, press this in for a few seconds.
Use the Web-updater at Garmin, to update it too,
Jack it to a PC and run the update,
If still playing up, Use the Firmware update at Garmin for it,
(( google Garmin 660 software updates ))
Should be good then
Regards
Richard.
May 18, 2009 | Garmin Nuvi 660 GPS Receiver
I try to turn on my garmin navigations system and it will not turn on. and i need to get some were.
I try to turn on the Garmin Nuvi and it will not go on. You can move the bottom to the on position but it just will not turn on. But when i charge it you can see the Garmin Nuvi on the screen and you can tell that it is charging. Please help. The model is Garmin Nuvi 750.
Bambi66
Oct 16, 2008 | Garmin GPS
Garmin C550
Remove the front faceplate, (there is an indentation under the word Garmin on the faceplate that you can use to lift it with your finger nail). After removing the faceplate you will see a reset button on the right side. Press the reset and then try to turn the Garmin on.
Jan 30, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Street Pilot 2620
Go to Garmin website http://www8.garmin.com/support/blosp.jsp and download the latest USB drivers.
Nov 03, 2007 | Garmin StreetPilot i3 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
