Question about HP Garden
Kohler 18 hp log splitter starter just wheres and doesnt start
4 Suggested Answers
SOURCE: Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Posted on Mar 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: My 2 H.P. electric motor on the Task Force 5 ton log splitter hums when I depress the start button but will not tturn
It probaby is the capacitor. Check for a loose connection or burnt wire on it. Use an old timey el cheaper meter on ohms to test it. Remove the capacitor being careful not to discharge it and check between the terminals. If you see a slight hop while reversing polarization then the cap is fine. If it has no reading it is open inside which is probably the problem. If it was shorted then the needle on the meter would move over and stay and that would cause the circuit breaker to flip everytime you try to start it. Probably a bad capacitor. Easy fix.
Posted on Nov 27, 2012
  • 2210 Answers
SOURCE: 18 hp kohler engine starts but doesn't keep running!!!!
You put in a question about your ride on. What is it you need?
Posted on Aug 15, 2014
Parts for Kohler Model# 13WVA1C5009; Serial# 1K105H20218
Hello Marty Wells,
Your Kohler unit resolves to a CUB CADET XT1-LT42
(see below)
Cub Cadet XT1 LT42 13WVA1CS010 13WVA1CS009 Cub Cadet XT1 Enduro Series...
Manual
Cub Cadet XT2 Enduro Operator Manual Page 36
Still not finding CARBURATOR parts...
I have had phenomenal success finding
parts for MUCH older units on eBay
(but it really helps to know what the carb looks like)...
ELSE...
In the U.S.A.
Yellow Pages, or contact Cub Cadet LLC at P.O. Box 361131,
Cleveland, Ohio 44136-0019, call 1-877-282- 8684 or
Log on to our website
at www.cubcadet.com.
In Canada:
Contact MTD Products Limited, Kitchener, ON N2G 4J1,
call 1-800-668- 1238 or log on to our website at www.mtdcanada.com
Hope this helps
Carnac the Magnificent
Aug 27, 2017 | Garden
My kohler engine on my oregon log splitter will start but will only run for about 1 minute before cutting off
I had a similar problem (only not with a log splitter). The problem was that the fuel filter was clogged. When the motor was off, the dirt would fall down to the lower side of the filter, allowing fuel to pass until the fuel was flowing again. It may not be your answer but it's an easy and low-cost fix. Best of luck!
Oct 23, 2016 | Cars & Trucks
Aug 15, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
Toro z148 -18 hp kohler won't start by key but was with recoil now neither will start ,have fuel and fire thought seat switch bypass it and was starting withthe recoil now nnothing ?
I had one that had a short in a connector that went between the key switch and the starter switch, as soon as I cut it out and touched the wires together it started.
Jul 17, 2014 | Garden
Ryobi electric log splitter won't return to startposautomaticaly
We have one of these splitters and the only problem has been a control valve sticking down. Oiled the valve button with silicon oil which seems to have helped. Be sure to close the bleeder valve when putting the machine away. We bought the machine from Home Depot. Use some headphones for your music! We have split rounds much larger than recommended by splitting from different sides. Hope this helps!
May 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a craftsman gt6000 18hp kohler garden tractor. I has been working fine, but last week I noticed a loud single click when i turn on the ignition and a loud single click when i turn off the ignition....
The noise is likely coming from the starter solenoid which is the heavy duty relay that sends battery power to the starter motor. If this is the case clean the wire connections going from the battery, to the solenoid and to the starter and try it again.
May 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dec 10, 2008 | Garden
Garden Logo
29 people viewed this question
Top HP Garden Experts
solver2010
andrewdwhite
ray gallant
Are you a HP Garden Expert? Answer questions, earn points and help others
