Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Whats this?? error code 07,007.40:8989 Arrrghhh Help
  • 2,072 Answers
Re: Whats this??
You have to remove the scanner document feeder. The there are 2 torx screws on back, one for each side cover. Remove those then pop loose they side covers, the front surround cover will pop off as well.
On back there is a white cover between the the 2 side covers, 2 more torx screws remove that back cover.
Then remove the ink loader. Where the sticks are.It is just dropped in and has a couple of plastic clips on the sides. That will expose the print head area. Between the print head and the drum, that is where the blade will be. And would be tacked to the front of the print head.
The other very likely problem is the print head pivot block. It is located, looking from the front of the machine, about mid way back on the lower part of the frame. It is a stainless steel block about one inch square that the print head shaft pivots on. It gets ink in it and causes the head not to move back and forth freely.
To remove that, there is a spring latch over it that you just pull back and latch on to the upper left. You may need to use apair of channel locks to remove that block if it is full of, normally yellow ink. Then soak it in very hot water to soften the ink, and clean it well.
Post your E-mail address I may be able to send you some additional info for this repair.
Posted on Mar 24, 2008
  • 208 Answers
Re: Whats this??
· The printer was powered off in the middle of a cleaning cycle and the wiper has frozen to the printhead.
· A Drum Maintenance Camshaft lobe is broken and holding the Maintenance Kit?s oil roller against the drum when it should be retracted to its home position.
· Process gearbox not being aligned correctly as described in the service manual and in Service Bulletin 714.
· A broken left or right printhead restraint.
· Ink spilled in the roll block preventing the printhead from tilting forwards/backwards or from traveling left/right.
· Ink or other debris under the printhead that do not allow it to fully tilt backwards or forward.
· The printhead wiper assembly not being aligned correctly or ink spilled in the wiper tracks on either side of the printer.
· The printhead tilt gear not being homed correctly.
· The X-axis motor nose cone not being installed correctly.
· The ferrite torrid on the printhead interface cable has slipped behind the printhead causing the printhead to bind when it tilts backwards.
· The black plastic shroud on the back of the printhead is snapped off and binding the printhead when it tilts back.
Posted on Dec 04, 2007
0 characters
3 Points
Error code is coming in my machine
To enter service mode
1) Press the User Mode key.
2) Press 2 and 8 on the keypad at the same time.
3) Press the User Mode key on the control panel.
And make power OFF and ON.
If not solved..
1.Check connection of the Connectors (Thermistor Connector
and AC Connector).
2.Replace the Fixing Main Thermistor (Film Unit).
3.Replace the Fixing Assembly.
4.Replace the DC Controller PCB
Hope this may help you to get clear.
Feb 13, 2015 | Canon Printers & Copiers
Error code E000002 in Canon IR2520
it indicates fixing unit temp could not raised to predetermined value. The following steps may be taken to clear the error.
CLEAR>ENGIN>ERRLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
4.Replace the DC_CON PCB.
If I turn on the machine ,it is showing me a error code.I dont know whats the problem.
Without knowing the error code I can't help you. Please let me know.
Dec 09, 2010 | Canon imageRUNNER 2200
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
Error Code 0xc19ac3ff
This problem seems to have occurred a few times... The only thing i would adise you to do is call HP and see whats the deal. Number is 800-HP-INVENT
Nov 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
173 people viewed this question
Top Xerox Printers & Copiers Experts
Level 1 Expert
Patrick Carmichael...
Are you a Xerox Printer and Copier Expert? Answer questions, earn points and help others
