How do you program functions for hearpump with auxlivery heat
  • Heating & Co... Master
  • 1,658 Answers
You have to enter the settings menu on the tstat. There you can set system configurations i.e. 1 stage heat 1stage cool heat pump 2 stage etc...
Posted on Apr 29, 2017
How do I bring up heat to 70 degrees on my Proselect PsTs21P52 thermostat which has been programmed?
Looks like you have a hold function. This will bypass the programming and "hold" your desired temp. If the temp rises but reaches a maximum of a certain degree than someone has set the maximum heat temp to that degree. Meaning you will have to enter the settings menu and scroll through to make the changes. You need the manual. Good Luck.
Apr 04, 2017 | Heating & Cooling
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Machine will only show one program time/heat setting (program runs through all cycles no problem but I cannot select a higher heat etc.) the dryer function stopped at the same time - is there a reset
It sounds like you have two appliances with two problems but you do not make that clear. It does sound like a circuit bowrd problem but you do not sday what machinew you have so all is just guessing.
Nov 24, 2014 | Washing Machines
The functions seem to be frozen. what do I do?
Try removing power to the thermostat including the batteries for 20 seconds and see if that solves the problem.
Sep 24, 2014 | Honeywell Th8320u1008 Visionpro Digital...
How do you defrost on the microwave
What is need to set the program, select defrost function then select the weight of the food to be defrosted and push the value of the weight. Now select the heat value and press start as the processor will then decide the time to defrost.
This is a simple program setting or else you can choose a preset heating defroster program.
Aug 19, 2011 | Microwave Ovens
I have just installed a RTH7400/RTH7500 thermostat. The wires are seem to be in the correct place, all functions are working, with the exception of no heat will come out, only cold air? I have set all...
Check function 0170 to make sure it is set on the proper type of heating system. Its a long list and specifics of system type make a difference. Also, Ive learned the hard way to always go by function, not color of wire. If you tossed the instructions they can be found on the Honeywell website
Nov 16, 2017 | Honeywell Focus 6300B 5-2 Days...
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
Trane Heat Pump
What caused the power outage? Check the outdoor disconnect to the condenser unit. The fuses may have blown, causing the heat pump to not function and depending on the aux. heat to carry the load.
Dec 16, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
