WHY IS THE "INVALID INPUT" SHOWING UP. I HAVE TO RESET MANUALLY WITH THE INPUT OF MY TV TO RECONNECT TO THE HD BOX.
I HAVE A(LTV-40HBG) SERIAL # 609HG000317
SOURCE: Sony WEGA KV-34HS420
check your cable
Posted on May 12, 2007
SOURCE: Connecting PS3 to HD TV without HDMI input
Component video input. Red, Green, and Blue. Your system should have come with it, but I don't know, I'm a 360 user.
Posted on Jun 06, 2008
SOURCE: Westinghouse 47"lcd tv
are you using an hdmi cable or the red blue and green cables that came with the xbox? if using the original cables there is a switch on them that sets it to HD or standard. hope that helps
Posted on Nov 29, 2008
  • 46 Answers
SOURCE: No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Green screen on Westinghouse tv LTV 32w6
green screen on hdmi is normally a defective hdmi cable. 1st try a different device , like a dvd player. if same problem try dif cable. if it still does not work you have a defective signal pcb otherwise known as a main pcb.
Posted on Apr 22, 2009
Tv will turn on(green on light showing) but no picture. was giving us problem for 1 day with 'invalid input' flashing then blue screen all connections are tight.
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope it help
Jun 01, 2010 | Astar LTV-40HBG 40 in. LCD HDTV
The picture from the cable tv will only stay on for a few second then the screen goes blue and it tells me their is no signal
Check if this happens using other sources of signal such as a DVD player or a playstation. This could be a problem with the port or the cable that the signal uses to get to your TV. If you can use a different cable or test using a different TV just to make sure.
Dec 13, 2009 | Astar LTV-40HBG 40 in. LCD HDTV
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
May 22, 2017 | Westinghouse LTV-32w3 HD Television
My Astar LCD TV is possessed!
My nephew had exact same problem, I fixed it by changing 8 puffed up capacitors in the power supply. They went out of business because they copied philips tv design and were sued by them.. The model was ltv-2601(canadian model) but all including ltv-2701, used cheap capacitors. Has been good for 4 months now.
Mar 20, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
No input signal
timberline did you reset the tv to factory setting this may solve the problem
Dec 26, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Nov 27, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
