Question about Toshiba Computers & Internet
I'm trying to bypass a Toshiba satellite L305 HDD password. Does anybody know how?
  • 2692 Answers
SOURCE: Toshiba Satellite L305 cmos password
Open it up ,. Take out the battery. Short the battery terminals. Reinstall the battery. Nolonger a Bios pass word.
Posted on Jan 05, 2009
  • 35 Answers
SOURCE: FORGOT HDD SYSTEM PASSWORD CANT OPEN TOSHIBA SATELLITE A105?
Long time ago , I was confronted with the password problem. Finally , my friend Jane introduce the Windows password Reset.It help me access windows. It's great!
http://www.resetwindowspassword.com
Posted on Jun 08, 2009
kamal1984
  • 1383 Answers
SOURCE: i have a Toshiba Satellite A105-S4084 and its
There are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Posted on Jun 15, 2009
  • 164 Answers
SOURCE: how to recover the HDD password?
1800 series is an older Tosh laptop..and unfortunately there isnt an easy way to reset it. Since I have a Tosh laptop also, I was more than just casually interested in your dilemma..what I found is that you have to get whats called a loopback adapter and attach to the parellel port and start it up. The loopback is altered so that certain pins are shorted across(not as bad as it sounds) so that the BIOS resets. Try this website if you feel up to the task.
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
www.aa1consulting.com
Posted on Jul 26, 2009
SOURCE: How to bypass bios password on a Toshiba Satellite 1305-s6858
the bios password is a tough one,
once i took out the bios password component, and it worked , but very small solder joints there
Posted on Apr 03, 2010
Default bios password toshiba l305-s5909
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot.
Jun 24, 2014 | Toshiba Satellite A135 Notebook
Default bios password toshiba l305-35909
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
How to reset a Bios Password on a Toshiba Satellite L305-S5933
I am glad to HELP YOU!
Usually to reset a BIOS password THE EASY WAY is a mechanical procedure: removing the CMOS battery.
That battery usually is a round one, about a quarter in size, and it can be found on the motherboard. So you have to open up the machine and to lift up the battery - gently and with a lot of care!!! - from its socket. Take it out about 30 seconds to one minute and after that re-insert it, put everything back into its place, screw all screws and turn ON your machine. You will have to re-enter the information for the BIOS [date, time, settings] but this way you will be able to bypass the password.
Some other things you can read about it HERE.
GOOD LUCK!
... and don't forget to RATE, please...
Apr 20, 2011 | Toshiba Satellite L305-S5933 Notebook
How to Bypass HDD Password on Toshiba L305
Turn on the laptop and keep pressing the F8 key till you get a black and white menu. Choose to run in Safe Mode (use the arrow keys to highlight it and hit enter) and when it gets to the login, choose the administrator account (may be password protected also, but usually is not) and go to Control Panel, then click User Accounts. Click the account your trying to log into and click the "Remove Password". Reboot the pc and now you can log into that account.
Cheers!
Oct 28, 2010 | Toshiba L305-S5955 Notebook
My laptop is a toshiba l305-s5934 , problem is: hdd password
The problem here is the password stops the system from loading.
If you locate a Toshiba Service Centre, they can remove it for you electronically.
Hope this helps.
Oct 23, 2010 | Toshiba Satellite A135-S2386 Notebook...
I have a Toshiba L305-S5955 laptop,everytime I turn it on a screen comes up , blue box enter current password. if anyone can help it would be great, thanks
This is either A hdd password or a bios password, you could try password, or admin / administrator as the password, or follow this guide, there are sometimes backdoor developers passwords that can work http://www.uktsupport.co.uk/reference/biosp.htm
Sep 30, 2010 | Toshiba L305-S5955 Notebook
Bypass toshiba HDD Password
Try this link:
http://www.laptop-repair.info/toshiba_bios_password.html
Mar 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite L305-s5900
You better login to safe mode at start up and change the password .
To enter safe mode press F8 when window is booting .
Nov 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
