Question about Microwave Ovens
Just inherited a Vking VMOC205SS. lights, control panel fan and turntable work but no heating. could this stil be door switch or different switch issue?
    Top Expert:
  • Microwave Ovens Master
  • 40,263 Answers
The internal fuse could be open or the magnetron may have failed.
Posted on Apr 30, 2017
JVM2070 heats, no "fan" while running, no turntable
Hi. It sounds to me like the control PCB was damaged and is not switching power to the cooling fan or T/T motor.... Does the oven light work?
Sep 11, 2009 | GE JVM2070 Microwave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too:
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave was installed yesterday by "handyman"
Sounds like you have a defective door switch, door switch mount, or (worse) possible damage to the "hooks" which go into the holes in the chassis to activate the switches. Be sure to unplug it first. If this is an over the range model, you should not have to remove it from the wall to fix it. Generally speaking, you remove the grille across the front, then you'll see a screw holding the control panel frame on. Once that's removed, you lift the control panel assembly up and out. Then you can see the door switches and lathces, etc. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here:
Mar 12, 2007 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
