Question about Cell Phones
Y wont my coolpad cell reset? I have tried paperclip in bottom of phone and it will not reset my screen is frozen cant get it to shut down
SOURCE: My cell keeps shutting down when i try to turn it on
i have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
Posted on Jan 10, 2008
  • 4 Answers
SOURCE: frozen phone wont change screens
hard reset, hold home button and sleep/wake button till see apple logo then release
Posted on Feb 05, 2009
  • 77 Answers
SOURCE: my touch screen cell phone wont do anything or load nothing
So you take out the battery then put it back. Then you press the power-on button and it powers up. After that .... nada. You cant gert it to do anything? What happens if you call the cell phone? Does it ring? Can you answer it?
If the answers are that you cannot get it to do anything - even answer calls then the firmware is corrupted. You will need to bring it back to the store to have it fixed.
Posted on May 14, 2009
  • 1111 Answers
SOURCE: magellan maestro 3100 frozen on blue screen tried
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Posted on Jul 19, 2009
  • 75 Answers
SOURCE: My cell phone screen is frozen and it wonr shut off or turn on.
You should reset yuor phone 1 time as reseting will make ur pone performance 100% fast.
Posted on Nov 30, 2009
I just got this phone 2 weeks ago it is frozen i cant access apps and the charger cord is broken
contact seller , must be under warranty. All goods sold must be fit for the purpose that they are sold for and yours is not. You should be able to A: get it repaired
B: replaced
C: refund
Aug 08, 2016 | Universal Coolpad 8810 3.5"" Capactive...
How do I do a factory restore on a Coolpad 3300A
http://www.hard-reset.com/coolpad-quattro-4g-hard-reset.html
Coolpad Quattro Hard Reset (Factory Reset)
    1.Turn off your Coolpad Quattro phone and pull out battery and reinsert it after a few seconds
    2.Press and hold both Volume DOWN + UP and hit POWER button until "Recovery mode..." showing on the screen. When the triangle with an exclamation mark appears touch the HOME touch key to enter Recovery menu.
    3.Select Factory reset/ wipe data. (scroll down with VOL down.)
    4.Select with power.
    5.Scroll down to Yes - delete all user data. Press power to confirm. If your phone is responding to screen input, then open Settings from the Applications menu. Tap Backup & reset > Factory data reset; click Reset phone and Erase everything to format your phone.
Jan 04, 2016 | Computers & Internet
Hi i have a coolpad avail 3300 and when i turn it on it doesn't go past the coolpad logo it stays stuck on that screen what do I do
Coolpad Arise locked on startup screen : perktv - Reddit
https://www.reddit.com/.../coolpad_arise_locked_on_startup_scree...
RedditApr 21, 2015 - The community doesn't take too kindly to it either. ... charged battery, or on just the power cord, but it will not go past the "Coolpad Arise" logo.
Coolpad 3300A wont go past the start screen where it says ...
www.askmefast.com > Computers & Internet > Security > Screen
Coolpad 3300a wont go past the start screen where it says coolpad? ... Coolpad won t go past start up screen ... Software for avail coolpad 3300a phone ..... Can i get a new 4g coolpad for mertopcs if part of the screen doesn`t really ... coolpad phone model 3300a always freezing at the coolpad logo and how to unfreeze it?
Jan 01, 2016 | Computers & Internet
How do i hard reset a coolpad 8810
http://androidxda.com/download-coolpad-stock-rom-models
use your pc and flash software from the page... and the right rom!!!
then update it again
Sep 20, 2014 | Universal Coolpad 8810 3.5"" Capactive...
My htc surround (windows 7 phone) wont turn back on if i hold the power button on it loads up to the white htc screen and stays on i tried taking the battery out to reboot it self but that didn't wrk...
PLease do a hard reset on the phone and here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Aug 04, 2011 | HTC 7 Surround Cell Phone
Frozen screen on recording
There's a hidden Reset button at the bottom of the Flip Mino. At the bottom of the camera, there is a screw base a tripod. Inside of that screw base there is a little hole. Use a paperclip and poke it into the hole. Hold it there for 7 seconds. You may need to repeat this process 3-4 times. This should shut down the video camera.
Mar 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Screen is frozen and the phone wont shut off
reset it by holding the top button and the main button on the bottom then the apple will show up then when the apple goes away do it again it will problably take a while just wait and it will turn on and be fixed
Feb 06, 2009 | Apple iPhone 3G
Zen freeze
quite common this, plug in the mains adapter hold down play and insert something like a paperclip into the reset and this should clear the problem
Jul 26, 2008 | Creative Labs Zen Touch MP3 Player
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
