Question about Garmin GPS
My Garmin Nuvi 265W will turn on but not load. I have tried holding the right hand corner etc. Any suggestion
    Scholar:
  • Garmin Expert
  • 186 Answers
Do a hard reset on the device. Download Garmin Express and install it to your PC. Connect your device to your PC. Garmin Express will identify it and allow you to install all the maps and software that the device has a subscription to.
Posted on May 02, 2017
Garmin nuvi 265w screen out of sinc
Try recalibrating the screen.
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Apr 05, 2014 | Garmin Nuvi 265W GPS Receiver
Tip
Garmin Nuvi 265W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 265W GPS unit.
I hope that helps.
______________________
Backup & Restore Nuvi 265W Favorites here.
Download Nuvi 265W Manuals here.
Download Garmin Nuvi 265W WebUpdater here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
I have a garmin nuvi sat nav which is just over a year old when unit is turned on all that shows on screen is the name garmin loading maps flashing on and off
Did you try a reset. Turn off the unit. Hold the bottom right side of the screen and turn the GPS back on. It will make you confirm you want to reset. It will clear out all you favorites etc.. so copy them first if needed. Then I would go to the Garmin site a register and update the unit. See if this works
I will attach Garmins contact info. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 15, 2011 | Garmin Nuvi 265W GPS Receiver
My Garmin nuvi 265W - when you turn it on is stuck on the loading maps page.. any suggestions
do this.,
1. get it connected to ur pc and see if it seeks any software update through garmin.com
2. if no updates needed, start again see what it does, if same stuck, while stucked in loading reset it by press and hold the tiny reset button for atleast 8secs and release , it should then come back to normal.
Pls let me know the result.
Thanks and regards
Jul 30, 2010 | Garmin Nuvi 265W GPS Receiver
My Garmin Nuvi 265W will not turn on
plug it in to the computer for a few hours, then hold the power switch to the on position for up to 15 seconds.
if that fails, disconnect it from the power source, then press and hold the lower right corner of the screen, while holding the lower right corner, switch the power to the on position. once you see the message "do you really want to delete your data" select yes, then follow the on screen instructions
bill
Dec 11, 2009 | Garmin Nuvi 265W GPS Receiver
I have a garmin nuvi 1300 and then i turn it on
it should show "loading maps" try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update, if not contact supplier for fix/replacement
Nov 03, 2009 | Garmin nuvi 1300 Car GPS Receiver
Nuvi 265w powers on but will not load
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Sep 21, 2009 | Garmin Nuvi 265W GPS Receiver
Restore garmin nuvi 265w gps to factory settings
Do a MASTER RESET for that.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. But who cares if you have problems, right?
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Jul 01, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 265w
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
I hope that helps.
Dec 25, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
29 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
