Question about Panasonic Televison & Video
Can't reduce the volume on my Panasonic DVD-s500
How to clean earpiece
Please press the [UP] arrow on the handset, while on an active phone call, to turn up the speaker volume. A Q-tip and soft cloth should be all that is necessary to clean the handset.
Mar 17, 2014 | Panasonic KX-TG1100 Cordless Phone
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
Sound is weak how to increase volume
Please check your all the audio and video connections. Also put the placing of AV Enhancer (button on remote control) in the ON position You can increase the volume by increasing the volume of the TV.
Dec 27, 2010 | Panasonic DVD-S27 DVD Player
Phone shows ringer is off..how do I turn it on?
Follow the steps
Press Menu--->Ringer setting--->Ringer volume----> press up button to ON the ringer.
You can reduce ringer volume by down arrow and increase volume by up arrow.
Thanx
Jul 24, 2010 | Panasonic KX-TG2343 Cordless Phone
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Sound output reduced
There is a volume control on the Remote of your DVD player , increase the volume in that and it should solve. Additionally check the audio output cord of DVD player if it is intact and tightly fitted.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 22, 2009 | Sony DVP-NS57P
Ringer not working
On the base press the volume up [^] key. Repeat pressing to get higher volume. Press volume down [V] for reducing the volume. Press and hold volume down for two seconds to turn ringer off. On the handset, you can use the menu to turn ringer on and off.
Nov 19, 2008 | Panasonic KX-TG2313 Cordless Phone
PLAYINGDISC'S
try reducing the burning speed and try with a different burning software
Oct 31, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DVD-LS80
I have the LS91 model and it tells you in the instructions what you need to do to get the extra time. Essentially you need to reduce the brightness to -5. This dulls the picture but if you are in a low lit room then it's no problem. To do this for this model you hit monitor mode twice and then reduce the brightness.
Cheers
Dec 08, 2007 | Panasonic DVD-LS80
Televison & Video Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
