Question about Magic Chef Refrigerators
Magic chef leaking water - Magic Chef Refrigerators
Krazytech
  • 725 Answers
SOURCE: water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Posted on Aug 25, 2007
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
  • 2418 Answers
SOURCE: why does my magic chef refrigerator leak water on
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Posted on Jun 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Magic Chef CTB1722 refrigerator leaking water from
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
What make a magic chef washer leaks only on rinse?
It probably leaked during washer very little by the time it comes to rinse you'll see more water
Jun 07, 2016 | Magic Chef Washing Machines
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
Magic Chef DU55CA-01 unit runs but when pump kicks on for discharge cyle water leaks on the floor from the what appears to be the solenoid part. The leaking stops as soon as the pump turns off. What part...
Leaking from drain valve shaft seal. If you just replace the seal it may still leak. Replacing the pump is a lot of work and not really worth it to cure a small leak.
Jan 24, 2010 | Magic Chef 24 in. DU6550 Built-in...
Magic Chef Side bye Side freezer started leaking
the drain line may be the problem. check to see if theres water in the bottom of the drain pan in the freezer compartment.
Mar 30, 2009 | Refrigerators
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Dec 31, 2008 | Magic Chef CAV2000AWW Top Load Washer
Refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Jun 26, 2008 | Magic Chef CTF2125 Top Freezer...
SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Feb 17, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Water squirting from ice maker
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Open Questions:
Refrigerators Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
