Question about Samsung Dishwashers
Samsung dishwasher over over water level code error
5 Suggested Answers
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
SOURCE: Low water level error with
Do you hear the washer draining (into the sink drain) after it fills and should start washing? Check that nothing (sound deadener, etc.) is interferring with the drain valve lever arm.
Posted on Feb 08, 2011
spucketts
SOURCE: Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
Posted on Jul 25, 2012
SOURCE: over-level water error
I finally found the cause of my "over-level water error", and I fixed it. In my case it was a gummed-up water level float chamber (part #13 in the diagram here). Once I pulled it out, cleaned it, and put it all back together the dishwasher is running fine. What follows are the symptoms I experienced, and some pictures of what I saw and did to fix it.
Symptoms: After nearly 2 years of owning a DMT400RHS, dishes began to progressively come out with sediment on them. They were not being cleaned nearly as well as previously. This symptom seemed to start fairly suddenly and remain for about 2 months. Then, the dishwasher began to occasionally error out, first with "Drain Error" or "Over-level water error", then later consistently with the "Over-level water error":
For awhile we could just restart the dishwasher and it would do a load. Later, however, no matter how many times we restarted, unplugged, etc. it would not continue. Of note, there was never actually a drain problem, as it would always, well, drain.
The error was never triggered during the initial "drain phase". It was always triggered after that phase, when it was filling the tub with water, specifically after it had been filling for awhile. Eventually, we figured there must be a float someplace that was all gummed up and not moving up with the water level.
Well, here's what I found when I finally pulled the entire dishwasher out and laid it down on its side (facing the door, tip it over to your right):
Inside that little box with all the sediment and glop is a wing-shaped float that couldn't move due to the glop. I simply held the whole plastic thing under the sink faucet to rinse it out. I had to take off the tub pan in order to pull off the drain hose that's attached to the back of this chamber. After rinsing it out, I put it back in and the dishwasher seems to be running fine:
Posted on Apr 21, 2013
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
How do you replace the water level sensor?
Samsung Dishwasher Repair oE code_CRICKET in Water ...
? 3:23
https://www.youtube.com/watch?v=YOvFYcaLp8w
Jun 22, 2014 - Uploaded by Mgionfriddo
Samsung Dishwasher failed less than a year old. ... Removedwater level sensor to inspect and found a dead cricket blocking the float inside of it. ... worst, it'll throw that error right after 2mins of power on, any ideas what to do next? .... Dishwasher HeaterReplacement - Samsung Dishwasher Repair (part ...
Dishwasher Water Fill Sensor Replacement - LG ... - YouTube
? 6:28
https://www.youtube.com/watch?v=JjM-4FAg0Nc
Jan 24, 2013 - Uploaded by RepairClinic.com
Dishwasher Water Fill Sensor Replacement - LG DishwasherRepair (part #6501DD2001A) ... instructions ...
Nov 24, 2015 | Dishwashers
What is error code LE?
An LE error code means problems with the motor. It can either be load issues, excessive suds, thermal overload protection, or a new installation. To solve this motor problem, you must first uncover the underlying cause.
Mar 24, 2015 | Samsung 24 Dishwasher DMT300RFS
Have over lever water error on samsung dishwasher
Your: Have over lever water error Probably means over level? In other words water is too high I would guess. Sounds like you have a bad water level sensor, or connections from or to and from or to the "brain" I'd unplug to reset the "brain". but it that doesn't help it's probably service tec time. Ask to estimate the price.
Mar 04, 2015 | Samsung DMT400RHS Builtin Dishwasher
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
What is a E3 code on Samsung dishwasher
The E3 error code on Samsung dishwashers is due to the overflow water level being abnormally high inside the machine, this is caused by a blocked pressure system. Start by checking the supply hose for kinks and restrictions.
Jan 20, 2014 | Dishwashers
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
Samsung dishwasher low water code
Your water level float is probably stuck. Take a look at this video and it shows you how to basically access this component. Use CLR to clean it out. Be careful to turn off your dishwasher breaker. Electricity and water do not mix well. Your dishwasher may be slightly different but Samsung dishwashers are pretty consistent in general as far as parts go. If you have at least basic mechanical skills you should not have any problem doing this repair.
Nov 28, 2017 | Samsung DMT400RHS Builtin Dishwasher
High Water Level ErrorSamsung DMT300
The parts mentioned, 8058475/SWITCH, PRESSURE and 8058500/HOSE are Asko parts. Samsung should have their own equivalent parts, but the Asko parts should work as well... I think the Samsung parts would be less expensive?
May 13, 2012 | Samsung Dishwashers
Dishwashers Logo
301 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
