Televison & Video Logo
How can I make my picture fill the screen? - Televison & Video
Make the picture fill the screen
my samsung has a blue button on the lower right side of the remote the botton is labled (P-size) pressing the button cycles the set for the several screen size functions.--Wide Fit--4:3--16:9. If you are watching network TV on an antenna you will get a full picture on 16:9, but you may be watching on cable without HD.
Picture does not fill the screen
Check the main output voltage (B+) from its SMPS regulator side. If this voltage is lesser than normal, picture won't fill the entire screen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Change TV resolutions to view slide shows
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
LG 55ln5700 picture does not fill screen
Go to picture/video settings and make sure your screen size is set for 16:9 or wide screen ratio.............
If you have dish or cable go into menu settings and check and make sure the same is true
Sometimes on the remote there is a picture size/mode button you can press to change the screen size
Normal or Wide would be widescreen
Stretch is zoomed picture that fills the screen
Letterbox is the square box screen
It sounds like a picture setting problem to me
I would try those things first
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Picture not filling screen
If it is a screen setting, wide screen, movie, other setting it may be as simple as that it would be a matter of menu settings. or if it is trying to decipher HD and it is not connected to an HD Reciever then it would not fill the screen.
Cant ajust picture to fill out screen, 3 inches
try this restore to defualt values monitor and cpu
3helpful
Picture not filling up the screen
The Vizio HDTV sets are all software driven. With the remote control select the menu option.
Then under the picture tab. look for the picture format full screen, wide screen. select the wide screen option. This setting should fill the screen.
Hope this helps
Bruce
1helpful
Picture in high def does not fill screen
That is normal. Most HDTV's have a format or picture size option on the remote or menu. It will give you options like full, stretch ot zoom to fill in the blank spots. The problem is those settings can also distort the picture size so people look funny.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
