Question about Power Computers & Internet
ALL LEDS GETS ON AFTER POWER ON - Power Computers & Internet
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Cause of no backlight on led td
Hi Jason,
Generally there are two reasons for no backlight in LED TVs. Either it is the inverter which produces necessary power to drive the backlight stops working or some of the LEDs in the backlight array fail. In some TVs even one failed LED will cause no backlight.
May 04, 2016 | Televison & Video
MY LINKSYS WRT150N ROUTER WAS CONNECTED TO THE MODEM VIA CABLE.IT WAS WORKING NICELY FOR WIRELESSLY CONNECTING TO LAPTOP AND IPOD AND ANOTHER LAPTOP/DESKTOP WITH A ASUS USB ADAPTER.THE...
Try turning off the power wait for 30 secs and reconnect the power and check if the LEDs light up again.
IF NOT THEN -
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 06, 2011 | Linksys Wireless-N WRT150N Router
Power, DMZ, WLAN leds OFF. Ethernet, Internet are solid ON.
With the signs that you have describe about your router, this is a clear signs that the router is already bad the hardware itself and better have it replace if still under warranty if not you need to go get a new one sorry about that router is dead already.
May 02, 2010 | Linksys Wireless-G WRT54G Router
Desktop doesnt start
may b your power supply is fail check Ur power supply. if that is OK it's mean Ur motherboard fault.
Feb 27, 2010 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
When turns on, tv gets off
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Check to see if you get any DC voltage on the output connectors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 16, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Power problem
Sounds like a short. A resistor probably burned out, and is causing unregulated power to hit your system. If you look at your main PC Board, underneath the turntable platter (disconnect your turntable), and remove the board. You'll be able to look at the board, and see if there are any burn sections on the board. If so, than the components around that area will need to be replaced. Generally R213 gets burnt, and Q2, Q3 get burnt, causing this sort of issue. This is not something I would recommend fixing yourself, and I would suggest seeking professional assistance.
You might also want to take a look at your fuses, which are located on the left side on a smaller PC board. If you don't see any fuses, then your unit does not have any fuses (common) installed.
Hope this helps.
- OPTiC
Digital Analog Therapy
www.DJPROLAB.com
Jul 14, 2008 | Technics SL-1200MK2 Turntable
Power on problem
A problemm is being deteced during the startup process. To prevent further damage, the set is shutdown. What you are seeing is repeated attempts to startup the set. If the set is less than 1 year old, it should still be under warranty. Call for warranty service.
Dan
May 28, 2008 | HP PL4245N 42 in. HD-Ready Plasma...
Computers & Internet Logo
19 people viewed this question
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
